Glow plugs? I have 215,000 miles on my originals...Where are you guys getting 75,000 miles to replace them? These aren't like gasser spark plugs!
Cost of ownership for a TDI is CHEAPER after the first 100,000 miles. Once you get past the first 100K it's money in the bank. The higher the price of fuel the quicker the payoff.
The trick to owning a TDI is simply follwing the manual for servicing. If you like changing oil every 3,000 miles and doing things just because you are bored then DO NOT buy a TDI.
Mileage dependent servicing:
Service intervals and costs if you do the servicing unless noted:
-Tire rotatiions - 7,500 miles - Free if you do them your self
-Oil and filters - 10,000 miles - $60.00 (Best oils + filter)
-Fuel filter - 20,000 miles - $50.00
-Air filter - 40,000 miles - $30.00
-Tires - 40,000 miles - $500.00
-Timing belt/water pump/pulley's/serp belt/coolant - 100,000 miles - $350 parts + $300 labor approx.
-Automatic transmission fluid change - 100,000 miles - $80.00 parts + $125.00 labor
-Manual Transmission fluid change - 100,000 miles - $40.00 fluid (OEM) + $40.00 labor
-New struts Bilstein - 125,000 miles - $600.00 + $250.00 labor
-Injectors (new nozzles) - 150,000 miles - $350.00 + $150 labor approx
-Clutch - 400,000 miles - $600.00 + $400.00 labor (modify the car and you will doing this right away due to torque limits on the pressure plate)
Time or Use dependent maintenance:
-Pollen air filter - 6 months - $30.00
-Brake Fluid - 2 years - $8.00 + $100 labor approx.
-Brakes rear (new rotors plus pads plus brake fluid) - $120.00 rear/ $140.00 front (pads and rotors and 1.5liters of fluid) + $100 labor approx
-N75 - $85.00 + $20.00 labor
-MAF - $120.00 + $20.00 labor
-Glow Plug - $13.00 - $10.00 labor
-Fan Control Relay - $140.00 + $30.00 labor
-Wheel bearing - $90.00 + $180.00 labor
-C/V boot + grease $40.00 + $100.00 labor
The point of all this is that the servicing of a TDI is actually LESS than on a gasser vehicle. The rest of the servicing is going to happen to ALL cars regardless of what motor you have. The TDI breaks even around 100,000 miles simply due to fuel economy EVEN if fuel cost per gallon is higher!
DB
