DOCTOR SHUMES
Tools necessary: 1. plastic bag
2. long skinny flat head screwdriver. 3. 13mm socket with rachet.
4. two spray cans.
Steps:
1. Open hood. Use flat head screwdriver to remove black cap off of passenger wiper arm (at base). place in plastic bag.
2. Use 13mm socket with rachet to remove nut off of wiper arm base. place in bag.
3. Close hood. Bend wiper arm up and wiggle it at the base until it comes off. Try rotating the arm straight up.
4. Open hood. Remove front rubber gasket(long) from the bottom of the rain tray/wiper cowl.
5. Remove pollen cover (not necessary but makes it easier) using torx wrench (similar to allen wrenches, puchased a set from sears $10.00).
6. Place the two spray cans on each side of the ECU (dead center with two wire harnesses sticking out toward you) under the rain tray/wiper cowl to help bend/hold up the bottom of the tray (originally thought of by Hesh, thanks).
7. Use flat head screwdriver to push the tiny plastic clips behind the connecter terminals on both sides of the ECU outward towards the corresponding sides of the car, as far out as possible.
8. Pull the two connecter terminals towrd you, towards the front of the car. Be sure to pull the whole thing, as the black boxes behind the wire covers are also part of the harness!
9. Use flat head screwdriver to bend the tiny piece of metal on the passenger side of the ECU which holds it in place.
10. Use flat head screwdriver to loosen the ECU by pushing it inbetween the gap of the ECU and the holding bracket.
11. Pull out ECU by wiggling it side to side and pulling. You may need to use the flat head screwdriver to loosen it more.
12. The ECU is a silver box about 4 by 3 inches with bosch writen on it.
For any questions just email me and i will be glad to assist.
DOCTOR SHUMES
2000 JETTA TDI
[This message has been edited by DOCTOR SHUMES (edited May 29, 2000).]
4. two spray cans.
Steps:
DOCTOR SHUMES
2000 JETTA TDI
