Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old June 4th, 2018, 19:52   #16
[486]
TDI(s): 02 golf ALH
Originally Posted by Billion003 View Post
Hybrid...doesn't that dictate automatic transmission?
honda did a manual hybrid civic and insight
the civic is the only one I've driven so far, was really neat, it'd shut off the engine sitting at a stop light in neutral, select a gear and it starts. If you stall it taking off, pull it into neutral and put it back in gear and it restarts. Such a freakin' cool feature, IMO.
I doubt you'd be forced to sell your car back, they might give you one heck of an offer you'd be dumb to refuse but forced? Unlikely.
Either keep it, or take the money and buy an older one with less craziness going on with the BCM running everything from the headlights to the door locks and windows.
Originally Posted by turbobrick240 View Post
I hope those five batteries wouldn't be lead acid. Even cave men have moved well beyond that battery tech. for EV usage.
You joking? They'd be used lead acid off the scrap pile. I'm cheap.
Old June 5th, 2018, 05:39   #17
atc98002
atc98002's Avatar
Yeah, I don't think there's a current hybrid with a manual. Some CVTs aren't too bad. I can accept the one in my Subaru, but a lot of that is because it's the 6 cylinder and has plenty of power so the engine doesn't really need to rev.
I think the current Lexus RX is the 450.
I sold my Passat back because the deal was too good to pass up. But it was hard to turn it in, because I really liked the car. I was hoping for the diesel Mazda CX-5 they keep promising, but it still hasn't arrived. Chevrolet has the Equinox diesel, and I would have bought that except I really wanted adaptive cruise.
I drove a used E-Golf last weekend, and that was a hoot to drive. However, the range is still a little too low for me to switch to full electric yet. Since VW still doesn't sell the new E-Golf in my state, used is all that's available, and those only have about an 80 mile range. The current model still only lists a range of 125 miles, and that is still a touch too little for me. Give me 150 true miles of range with the HVAC working and less than ideal conditions, then I'll consider it.
2018 Subaru Outback 3.6R Touring
2005 Ram 1500
2013 VW GTI: daughter
2010 Routan: other daughter has 3 kids
atc98002 is online now   Reply With Quote
Old June 5th, 2018, 05:49   #18
kjclow
Your experience with the civic hybrid manula sounds better than mine. I looked at them about 13 years ago and thought the manual did more to keep the stop start technology from working correctly. Unless I was absolutely still, any time I released the clutch the engine would start. Even with the car in neutral and the brake fully applied. Reminded me of the hill hold feature we had in our 82 subie. The only time it worked was when you came to an absolute complete stop and pushed the brake pedal through the firewall before taking the car out of gear.
Old June 5th, 2018, 07:51   #19
[486]
TDI(s): 02 golf ALH
Get a nice welder/generator on a trailer.
Drag that around when you want more range.
Old June 5th, 2018, 07:55   #20
[486]
TDI(s): 02 golf ALH
hm, that's strange, I'd have noticed that for sure as the only way I sit at stop lights is in neutral with my leg not getting all cramped up.
Maybe the A/C was on? I don't remember if those were engine driven or electric compressors on those, being early hybrids they may well have been engine driven and therefore they'd run the engine just to get A/C.
Old June 5th, 2018, 08:22   #21
kjclow
That could explain it. I run AC probably 48 out of 52 weeks a year down here. Still have that thin Midwestern blood from growing up in Iowa.
Old June 8th, 2018, 11:17   #22
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
One thing to point out with the voltage systems is OSHA regulates certain safety gear above I think 50 volts. That is why most forklifts stop at 48 volts and commonly are 36 or 48 volt systems.
Good to see there is hope in diesel future yet. The Chevrolet Equinox diesel I wasn't even aware of. Too bad it doesn't hall a family of 6 around so it doesn't give me much better usage then driving two MKIV diesels around but maybe someday in the future. I will be getting the 6.0 powerstroke Excursion running I bought on the cheap soon to be my family diesel mover (if the van is broke down or I need to haul a trailer).
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old June 8th, 2018, 15:15   #23
flee
Fuel Economy: 40-ish
Originally Posted by coalminer16 View Post
One thing to point out with the voltage systems is OSHA regulates certain safety gear above I think 50 volts. That is why most forklifts stop at 48 volts and commonly are 36 or 48 volt systems. (edit)
Well, be sure to suit up next time you're on one because the nominal voltage of a
48 VDC lead-acid battery system is 50.4 volts and the charging voltage is almost 60!
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline   Reply With Quote
Old June 10th, 2018, 07:20   #24
Dannyboy
Dannyboy's Avatar
Fuel Economy: 2014- 1168km per tank
I believe it's 60 to 1500 volts is classified as high voltage. I'm going for my high voltage auto tech course in a few months and I've been reading up on the course.
Dannyboy is offline   Reply With Quote
Old June 14th, 2018, 09:01   #25
coalminer16
TDI(s): Golf 2004
NFPA 70e 130.2 Electrically Safe work conditions. Energized electrical conductors and circuit parts operating at voltages equal to or greater than 50 volts shall be put into an electrically safe work condition before an employee performs work >>>>>>> and on and on it goes. National Fire Protection Agency standard 70 e which deals with the electrical safety in the work place that OSHA references if giving citations. It does reference NFPA 70b which deals with the maintenance of the electrical system as well.
It also states"Equipment operating at less than 50 volts. Energized electrical conductors and circuit parts that operate at less than 50 volts shall not be required to be de-engergized where the capacity of the source and any overcurrent protection between the energy source and the worker are considered and it is determined that there will be no increased exposure to electrical burns or explosion due to electric arcs.
I can't find the definition in my books off hand on the high voltage but I know high voltage doesn't start until at least 600 volts. Plants typically work no higher then 480 three phase and that isn't in the high voltage range. At least in the eyes of the regulatory agencies it doesn't consider it high voltage. I don't play with it and take it very serious when I have to work with it. Volts or amps - each have there own scary issues. Volts make the arc jump - it is the amps that kill you though.
Old June 15th, 2018, 15:20   #26
Billion003
TDI(s): 2011 Golf
At my dealership, the service manager said they could sell more manual transmissions if they were available to sell. He implied the excuse of the lack of demand was not the whole story in their lack of availability.
Billion003 is offline   Reply With Quote
Old Yesterday, 22:55   #27
German_1er_diesel
German_1er_diesel's Avatar
TDI(s): BMW 118d
Right now, there's a bunch of manual transmission mild diesel hybrids on the market, with more coming out soon (Hyundai/Kia are entering the market with diesel hybrid version of their compact CUVs).
https://www.motor1.com/news/242182/k...l-mild-hybrid/
I think they are all using the Continental system. Not sure about the Suzuki mild hybrid (gas turbo) cars.
Here's a test drive of a Renault Scenic (Which has been in production with the system with a diesel/manual for some time) and a Golf (Continental tech demonstrator).
https://www.youtube.com/watch?v=yC76hK3MrOs
New Audis (A6/A8/A7) come with a Continental 48-V mild hybrid system as standard, however not with a manual.
BMW 118d hatchback
German_1er_diesel is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
atc98002
Concept Car: VW unveils Diesel Electric Hybrid Twin-Up! Terrific-In-Tahoma TDI News/Tech 19 December 8th, 2013 17:23
VW looking at a "mild hybrid Jetta" for California candrews4tdi General VW Discussion 0 January 31st, 2007 11:32
Auto supplier believes in diesels V TDI (Diesel) Emissions 0 February 15th, 2005 07:13
Auto supplier believes in diesels !!! (link ) HAMMERFALL General VW Discussion 0 February 15th, 2005 06:01
VW Brings Diesel Mild-Hybrid Concept to Shanghai BrandonH TDI News/Tech 0 October 14th, 2004 13:43
Page generated in 0.15060 seconds with 12 queries
[Output: 120.58 Kb. compressed to 102.77 Kb. by saving 17.81 Kb. (14.77%)]
