Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old May 30th, 2018, 02:23   #1
dhslider
TDI(s): 1.9TDI AFN
Default 1z not starting
Hello all, i was wondering if i could get some advice,
I swapped my old AFN engine with a 1Z engine with the old AFN turbo and put the AFN injectors and pump on the 1Z block. The ECU is also the AFN one but after doing all of that the car wont start. Timing is spot on and i've tried turning the pump, but no luck. Weird thing is that the vcds says that the modulating piston movement sensor is only getting 0.75v instead of the 1.5v that it should get? And the injection valve is 95% open when the ignition is on but when you are cranking it goes to 45%, have also tried swapping crank sensors.
dhslider is offline   Reply With Quote
Old June 12th, 2018, 11:57   #2
dhslider
TDI(s): 1.9TDI AFN
bump.
Old June 17th, 2018, 12:32   #3
Kaktuss
I had something similiar. Changed my 1Z to AHU. Changed the ECU still didn't start... changed the immobilizer block and the engine turned on the first turn.
Kaktuss is offline   Reply With Quote
Old June 18th, 2018, 04:29   #4
dhslider
TDI(s): 1.9TDI AFN
I dont think it is the immobilizer because the light for it turns off like normal? And i used the old cars ecu aswell?
1Z not starting IronBenderII TDI Conversions 14 December 17th, 2017 10:35
Hard Starting when Hot (1Z TDI) markd89 TDI 101 8 September 6th, 2017 17:04
1Z Starting issue - starter, battery or? markd89 TDI 101 0 November 15th, 2015 11:03
1z starting issues pirate6 VW MKIII-A3/B4 TDIs 2 January 24th, 2012 13:24
Hard starting 1Z JAMTDI TDI 101 4 December 17th, 2007 08:51
Page generated in 0.12506 seconds with 12 queries
[Output: 60.94 Kb. compressed to 54.61 Kb. by saving 6.34 Kb. (10.40%)]
