Old June 16th, 2018, 06:07   #31
travis45
travis45's Avatar
What is the tw?
14 Sportwagen TDI CR170 Frankenstien hybrid 2056 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD.
travis45 is offline   Reply With Quote
Old June 16th, 2018, 08:37   #32
mrchill
Super Secret Diesel Ninja Vendor
mrchill's Avatar
Location: MASS! home of THE WORLD SERIES CHAMPION RED SOX! x 2!
Turbine wheel.
How do you know you are alive if you are not miserable?
If you were traveling at the speed of light, and you turned your lights on......would anything happen?
What if the hokey pokey really is what it's all about?
You will get NOTHING! And you WILL be GRATEFUL!
mrchill is offline   Reply With Quote
Old June 16th, 2018, 11:25   #33
sam-
I have a gtb2060vklr that i will try to adapt on a Golf mk3 afn, would you advice to avoid using restrictor too ? Any tips for installation ? Thanks in advance.
Originally Posted by TheoSweden View Post
No problems with 2260VKLR here! They are designed to last 1 000 000km, so if the installation isnt done bad there should be no issues.
I use no oil restrictor!
sam- is offline   Reply With Quote
Old June 16th, 2018, 14:42   #34
travis45
travis45's Avatar
I believe the GTB2260vklr MecEvo is building me has a billet compressor wheel and a stock turbine wheel.
Old June 17th, 2018, 09:08   #35
TheoSweden
TheoSweden's Avatar
TDI(s): A3Q,A4Q
I was told the restrictor was in the turbo. So I just installed a 1/4" hose to it.
Other than that just make sure return line is in good angle.
TDI Project: VW Golf 1 - 83
Track/Ice racer: Audi A3 TDI Q - 02 ~280hp
Daily driver: Audi A4 TDI Q - 08 ~300hp
http://65.110.12.166/showthread.php?t=378371
TheoSweden is offline   Reply With Quote
Fun build just need to pick a turbo. miatamike203 TDI Power Enhancements 48 December 31st, 2016 19:23
New Turbo: Help Me Pick One storx TDI Power Enhancements 60 March 3rd, 2014 08:07
Pick my turbo Diesean TDI Power Enhancements 6 October 2nd, 2013 16:31
FS: VNT-15 Turbo Pick-up only Sebpt Ontario 1 April 27th, 2009 11:26
faint turbo but great pick up ljnoel TDI 101 20 May 8th, 2008 09:12
Page generated in 0.13043 seconds with 12 queries
[Output: 72.25 Kb. compressed to 63.97 Kb. by saving 8.27 Kb. (11.45%)]
