Being a newbie to the diesel world can someone point me to the location of the oil filter on the Passat 2.0L 134 hp engine? I'd like to visually inspect same before taking it to the dealer for the first oil change. Thanks...
I didn't find any pictures on the web of the 2.0 TDI engine compartment.. I'm just making a guess that it's shaped like cylinder with a cap about the diameter of an orange. It most likely has flat edges all around the cap for removal via an oil filter wrench. You may have to remove your engine cover to see it. Hope this helps. /images/graemlins/crazy.gif
That's a pic of the 90hp ALH engine. The original poster is asking about the new 2.0L engine in the Passat.
AFAIK a pic of the engine compartment has not been posted. Maybe a kind club member with a new Passat TDI would be kind enough to post one with the engine cover taken off!!!
Thanks guys!!! If anyone has a picture of the 2.0 TDI with the engine cover removed and can point to the oil filter it would be much appreciated. Otherwise, thanks again for the tips.
