tdwesty
- Joined
- Nov 9, 2009
- Location
- Vancouver Island, BC, Canada
- TDI
- '04 Jetta TDI GLS Spice Red, 1.6TD Westy
Today I went to replace a noisy outer CV (boot split for a few years which I've ignored...) and found my Meyle 1J0 498 099E replacement kit (new CV & boot) doesn't fit! Splines from CV to axle are too large, and the outer diameter of the CV is also larger.
So either the parts listing is wrong, or someone has swapped the entire axle to use one with a smaller CV, possibly from an A3 or even A2?
Has anyone seen this before? I guess I'll be cleaning and re-packing the old joint after all. But I still need to find the right sized boot, presumably from an A3 or A2.
Mine is an '04 5 speed Jetta TDI (BEW).
