Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old June 12th, 2019, 05:28   #1
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
Default 07 Jetta 2.5 AC problem
Takes a while to cool, somewhat intermittent cooling, occasionally pretty cold air from vents (will check vent temps today). This has been going on a while. Pressures with car warm and air temperature of 68 F were 68 low and 105 high. I'm thinking the frequency valve is failing (RCV). Good idea or should I replace the compressor? Thanks.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Old June 12th, 2019, 06:06   #2
oilhammer's Avatar
Fuel Economy: fantastic
Yep, RCV. Make sure BOTH fans are operating, too.
www.cardocautomotive.com
Old June 12th, 2019, 07:02   #3
RabbitGTI
RabbitGTI's Avatar
Thanks, will do.
Old June 13th, 2019, 17:19   #4
03GolfTDI
I concur with oilhammer on RCV and fan.
My '06 2.5 one of the fans failed, I really only noticed it because the other one ran at full tilt to try to keep up - this was just under 70k miles it went bad.
Adam
'12 Jetta Sportwagen TDI DSG - 67k
Platinum Gray/Titan Black
'11 Jetta Sportwagen TDI DSG - 48k
Candy White/Beige
03GolfTDI is offline   Reply With Quote
04 Jetta AC problem cruisinflatout VW MKIV-A4 TDIs (VE and PD) 3 April 15th, 2017 11:33
AC problem 2002 Jetta TDI ColdStartTDI TDI 101 3 July 1st, 2016 19:17
AC problem, 2000 TDI Jetta Kawayanan VW MKIV-A4 TDIs (VE and PD) 1 August 21st, 2012 13:59
09 Jetta AC problem chiefmoose VW MKV-A5 Golf/Jettas 0 June 6th, 2011 15:51
03 Jetta AC problem - again :) MilenP TDI 101 14 August 11th, 2006 06:56
Page generated in 0.12615 seconds with 12 queries
[Output: 63.96 Kb. compressed to 56.93 Kb. by saving 7.03 Kb. (11.00%)]
