Throttle body gasket?
digdug
vineland NJ
2013 jetta tdi
Is there such a thing as a TB gasket? Someone is working on my car and said I should order one - he isnt a TDI mechanic but has a lot of experience with diesel motors (Mann diesels for boats/ships). I looked on metalmanparts and idparts but dont see any
thanks
digdug
vineland NJ
2013 jetta tdi
I'll let him know: thanks !!
he just sent a txt saying "well the throttle plate is there and it gets engaged by sensor which is next to egr and shutter valve"
josh8loop
Vero Beach, Fl.
2002 VW Jetta TDI Manual(performed 01M to 5-speed swap) - 183,000 miles and climbing!
"O" ring
Digdug,
There is a large "O" ring that is between the air intake manifold, and the EGR/Antishudder intake assembly. I had to replace mine recently because I saw oily goo coming from that area. When I went to replace the "O" ring I NOTICED THAT IT WAS EXTREMELY BRITTLE, LIKE HARD PLASTIC, AND NOT LIKE RUBBER. I guess that would certainly cause a leak :) I also had to replace the EGR tube gaskets since I removed the EGR/antishudder intake assembly to replace the "O" ring. I got mine from the dealer, and it was 13.00 or so.
