Radioflyer
I am looking to mate a VW motor to a 3.4l R150
Need help with clutch,starter,pilot bearing.
What is my best setup for a starter using a 3.4l bell housing? This is a gasoline motor so I dont need an high torque starter.
I plan on having a later 22re flywheel drilled for vw crank if There is abetter option let me know.
If I can redrill the 22re flywheel then I plan on running the 3.4l pressure plate
Then it pilot bearing. What is everyone using for a pilot bearing?
