2013 Passat. This thing is driving me nuts. The placement of the exhaust flap and the wiring is pure garbage if you live in the country on gravel roads. I have replaced the valve once had to redo the wiring numerous times. This time the wiring got knocked out of the clip and broke my zip ties and rubbed 2 wires in to and messed another up. It has the glow plug light flashing without and codes that really mean anything. The exhaust flap is stuck open and I cant make it turn using my scanner. Could this flap be bad also and cause the blinking glow plug light? I have the wires soldered back together. Before when it crapped out it just threw a code for the exhaust flap. This thing is about to get traded off if it keeps having stupid issues. Any ideas would be appreciated.
Also only code it shows is P064100 and had the P047500 when I was messing with the exhaust flap.
