coalminer16
2004 Golf PD BEW. I need to find the part number for the fuel hose going into the tandem pump on the side of the head and if someone knows where to order that would also be nice. I am to far from a VW dealer (still) and there open hours don't work out with the hours I work so an online place would be nice. Thanks for the help. Mine is starting to weep. The hose is not dripping but the whole hose is wet and has been cleaned off but it becomes wet again. I just don't want to spring a larger leak. Tandem pump is NOT leaking nothing else it leaking but that hose feeding into the tandem pump.
