Michael Aos
I keep reading that Volkswagen vehicles have a reputation of being unreliable.
Is that still the case? Or are the new ones likely better?
Sorta...I'm confused. You have apparently gone ahead and purchased a 2013 JSW (based on your signature) and you're asking if they're still garbage?
I am pretty impressed with that. I'm coming from a 2005 Outback XT Limited 5MT -- 2.5L turbo / 250HP & 250 ft/lbs of torque.there's the crazy torque that induces grins all around when you press on the go pedal.
If you want a fast diesel car get a BMW 335d. Take it from the man who owns one....they are rocket ships.I am pretty impressed with that. I'm coming from a 2005 Outback XT Limited 5MT -- 2.5L turbo / 250HP & 250 ft/lbs of torque.
The SportWagen is similarly fun to drive. The Outback is a lot faster -- if I do everything right -- right gear, right RPM -- but the SportWagen DSG does a pretty good job of figuring that out itself.
I was wishing for a faster 0-60 yesterday as I was trying to merge onto the highway as a Ford Flex was bearing down on me. In retrospect, maybe I should have tried Sport mode.
Doesn't really have to be that fast -- my Outback XT will do 130mph, but I don't normally drive it that fast.If you want a fast diesel car get a BMW 335d.
I bought it thinking I'd drive around 11K miles/yr and get rid of it around the 4yr mark.
I somewhat recently purchased a used 2005 Outback XT Limited w/5MT (5-speed manual). It had about 102K on it when I bought it.why did you get this car just to get rid of it so quickly? 44,000 miles is nothing on them.
I've been switching vehicles a LOT more than I or (especially) wife would prefer over the last couple years.\why did you get this car just to get rid of it so quickly? 44,000 miles is nothing on them.
I'm showing $.183/mile on my 2005 Outback XT Limited -vs- $.108/mile so far in the SportWagen.a gas Subaru probably isn't too bad either, until you have to fill it up. Those things appear to be very thirsty according to Fuelly.
My 335d has 425 lbs ft of torque at 1750 rpm. It will go very fast, instantaneously with less effort than anything Ive ever driven. Sure my hemi roadrunner is faster for a quarter mile, but it lets you know about it and it sure as heck wont go 155I guess I'm more impressed with the power difference because I was most recently driving a 2002 Golf TDI. To me the JSW is like a rocket compared to the older engines. But I'm sure the BMW is even more impressive. And a gas Subaru probably isn't too bad either, until you have to fill it up. Those things appear to be very thirsty according to Fuelly.
If you want to own it for 4 years and dump it, it's not a horrible idea if you're really worried about the potential for expensive fuel system problems. By then the 7th generation car will be out and somewhat proven (or not). I have no idea how long I'll keep mine, but I'm enjoying it for now and would like to get at least 8-10 years out of it.
I'm at about 725 miles so far.use a good lubricity additive if you want, and break it in properly.
Is there a down side to B5?B5 should have more than enough lubricity.
You have FIVE vehicles and drive them all? That is hard to believe. May be you explained this earlier. To the topic. When you talk "Reputation" we are talking about public perception and many social factors. Go to all the car lists, J.D. Powers, Consumer Report, NHTSA (National Highway Traffic Safety Administration), Insurance Institute for Highway Safety... on and on. Look at repair, customer satisfaction and reliability... Yes reputation, VW has a reputation as being less reliable or not having as high customer satisfaction as Lexus or Acura or Toyota....Ford as a brand. However I am happy so far. You also have to compare apples and apples.I keep reading that Volkswagen vehicles have a reputation of being unreliable.
Most of the reported issues with bio diesel happen at concentrations above 20%. Should be no real issues with B5 as long as you're buying it from a station with high turnover.Is there a down side to B5?
I was down to around 1/4 tank, so I filled it up w/B5.
Would it be "better" to fill it more frequently when traveling? I was thinking it might help minimize the chance of getting a whole tank of bad fuel. But on the other had, it might increase the chance of getting some bad fuel.
I'd like to read that CR article......(do you recall what month?)For what it's worth, Consumer Reports gave the '13 JSW high marks.
You do? I should have you talk to customers who call us with '05.5 and '06 Jetta TDIs with failed camshafts, busted throttle bodies, leaking EGR coolers, failed coolant hoses to heater cores, broken wires in the engine harness causing misfires, and broken door wires that cause windows to fail. Or turbos with actuators that aren't available as replacements. Or failed dual mass flywheels, both on manuals and DSGs. Some of these things happen in the first 50K, some around 100K, some later.I think VW turned the corner on reliability when the MkV came out.
