I am hoping that all of you with much greater experience then I, can point me in the right direction. I assume that I need a new ABS module as my ABS/ESP/Brake MIL dash lights are flashing and the ABS/ESP do not work. But if there is anything else that I can check first before I replace the ABS module I would appreciate the input.
Faults: 1130, 1316, 0625
Code:
Saturday,08,February,2020,12:02:59:21118
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: 3VWRL71K49M077162 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 65 72
77
VIN: 3VWRL71K49M077162 Mileage: 265650km-165067miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 H HW: 03L 906 022 J
Component: R4 2.0l TDI G001AG 9983
Revision: 12H01--- Serial number: VWX7Z0H824T1FY
Coding: 0050078
Shop #: WSC 59049 001 1048576
VCID: 333319C1D7304F7F045-8066
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 8938
Revision: 04843012 Serial number: 00000809052030
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 51FF73494DEC1D6F169-8004
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B400D49290001880C02EA921B0042B100
VCID: 77ABEDD18FC8635FF8D-8022
1 Fault Found:
01130 - ABS Operation
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 110
Mileage: 258479 km
Time Indication: 0
Freeze Frame:
Count: 1
Count: 0
Count: 4608
Count: 125
Count: 47624
Count: 771
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 78A9EEED8ED66C27F17-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000001108144
Coding: 14018E234004150007140000001400000008730B5C000120000000000000
VCID: 323D1CC5282A46770F3-8066
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 251008 021 0501
Coding: 00038805
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M07BN1+
Coding: 0013889
VCID: 6C81C2BDCA8ED08705F-8038
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME3F34230EF
Subsystem 3 - Serial number: 6342MSME3F333934F
Subsystem 4 - Serial number: 6351HSME1837717CD
Subsystem 5 - Serial number: 6361HSME183659123
Subsystem 6 - Serial number: 63727SME18582E110
Subsystem 7 - Serial number: 63827SME185870392
1 Fault Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 057 0101
Coding: 0012021
VCID: 04518A1DC21E38C7EDF-8050
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0003000 Serial number: VWX7Z0H824T1FY
Coding: 0023203
VCID: 392F2BE9F55CB52FCE9-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 070908F1000345
Coding: ED807F074006121002
Shop #: WSC 08353 444 84822
VCID: 353727D9D944514F2A1-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2418
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 A HW: 5N0 035 342 A
Component: SG EXT.PLAYER H13 0062
Revision: A1001003 Serial number: 7667021889
Coding: 010000
VCID: 2517F79965E421CF9A1-8070
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 HW: 3C0 035 684
Component: RNS-MID H17 0210
Revision: AB001001 Serial number: VWZ6Z7H6261016
Coding: 040004000400000600
VCID: 6099A68D3A4684E7A97-8034
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 254
Reset counter: 155
Mileage: 216203 km
Time Indication: 0
Date: 2000.00.00
Time: 14:35:42
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000658488926
Coding: 0001205
VCID: 6FBBD5B1FB982B9F20D-803A
2 Faults Found:
00105 - Signal Central Locking SAVE/LOCK Drivers Side
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 101
Reset counter: 155
Mileage: 258390 km
Time Indication: 0
00109 - Left Mirror Turn Signal Lamp (L131)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Reset counter: 155
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A0D04A500FA0EB7B73-807E
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DC00
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08081216383401
Coding: 0001204
VCID: 70B9D6CDE6A63467397-8024
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 155
Mileage: 216203 km
Time Indication: 0
Date: 2000.00.00
Time: 14:35:42
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003534686
Coding: 0001168
VCID: 76B5E0D584C21A57E3B-8022
Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
Component: RDK 0450
Coding: 0100101
1 Fault Found:
00625 - Vehicle Speed Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 33
Mileage: 261527 km
Time Indication: 0
Date: 2000.00.00
Time: 10:54:44
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003541411
Coding: 0001168
VCID: 77ABEDD183C8635FF8D-8022
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 051 730 B HW: 1K8 051 730 B
Component: Telefon H02 5400
Revision: 00002000 Serial number: 20389520116183
Coding: 412120
VCID: 2615F09518E22AD793B-8072
End----------(Elapsed Time: 01:33, VBatt start/end: 12.2V/12.3V)-----------
