Snownut
- Joined
- Jun 17, 2002
- Location
- Layton, Utah
- TDI
- 1998 Jetta TDI (White), 2007 Jetta Wolf (Reflex Silver)
Ok, I have been working on a problem that my 98 Jetta has for a couple years now and just can’t seem to pin point the problem. It isn’t a major issue, but occasionally just gets under my skin.
The car on long steep grades will drop into limp mode and lose power. If I cycle the ecm (key switch) and pop the clutch it will come right back to life.
I added a boost gauge recently and in town everything seems to be great. The car shows under hard acceleration a peak boost of 16-17 psi then drops off to 14-15. At cruising speed with a little headwind it shows around 4-5 psi. You wouldn’t know anything is wrong in town or normal highway driving. The pick up is great and for the most part the car seems normal.
My main concern at this point is that in conjunction with the boost gauge I installed a Dawes in parallel with the N-75. Around town or highway everything is fine and the boost is the same with or without the Dawes. However, now while climbing a steep grade I can only pull around 10 psi boost and it seems to continually (gradually) lose power even when shifting down and doesn’t seem to go into limp mode (no cel).
I seriously am at a loss with this car. I am going to take it up the canyon again today after work without the Dawes, and monitor the boost as it is stock, but am sure it will drop the turbo again.
What am I missing? Something has to be at the root of this problem…
Here is what I have done to this point.
-Cleaned the intake system, manifold, intercooler etc.
-Changed the hose from the intercooler hose to the ecm (twice now).
-Replaced ecu internal hose.
-Changed the n75 and all three hoses associated. (red, blue and black).
-Took the turbo off and was going to have it rebuilt but both reputable turbo shops I took it to checked it thoroughly and said there isn't anything wrong with it or the waste gate.
-Checked all the intercooler hoses for any leaks, cracks etc.
-Changed fuel filter.
-Changed air filter / removed snow screen.
-Installed Boost Gauge.
-Installed Dawes in Parallel with n-75.
Any words of advise would be greatly appreciated..
10q
10q
