KrashDH
So I've had scattered threads here and there the last 6 months as this car hasn't let up with giving me issues. Back to back to back it seems.
After replacing basically all the front end parts last weekend, I was doing my normal commute and test run on all the parts. It felt great. Was heading to the gf's house to pick her up for a hockey game when the low brake light fluid came on. All pads, rotors were new, fresh bleed all around.
Crawled under the car, right rear caliper gave up the ghost, was leaking pretty bad. Banjo bolt and bleed screw are dry.
I'm going to rebuild both rears while I'm doing the failed side.
I haven't dealt yet with the wind in pistons style.
I've done reading, searched threads, it doesn't seem too bad, but I wanted to ask yall if I should look out for anything in particular.
Car isn't subjected to salt so I'm re using pistons. They all move freely as I checked when I did the brakes. Parking brake mechanisms are in good shape.
So I bought 2 of these kits (I have 38mm pistons stamped in the calipers):
Centric 143.33031:
https://www.amazon.com/Centric-Parts-143-33031-Caliper-Kit/dp/B000IY9NQU
A set of pliers to get at the snap ring:
https://www.amazon.com/Motion-Pro-0...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
The disk brake kit (for piston removal/installation):
https://www.amazon.com/OrionMotorTe...tor+tech+disc+brake+kit&qid=1582159416&sr=8-1
2L of Pentosin Super Dot 4
A power bleeder since I'm a 1 man operation
Is there anything else I should get? I'm either going to use some expanding ear plugs to plug the banjo bolt while I work or use vacuum nipple end plugs to seal the m12 hole. Either should work.
I need this car to be flawless come end of March as I have a big time front end rebuild project on the truck. I've felt as of late I've been walking on eggshells around this car and I've proven it by all that's gone wrong. I haven't driven it for a week straight for months without an issue.
Thanks in advance!
Centric 143.33031:
Thanks in advance!
