VanagonWestyTDI
Hello everyone, this is my first post here. I've been lurking in the background for over a year reading posts and comments while I worked on my 82 Vanagon swap.
Over a few months ago I swapped an AHU motor from a 98 Jetta into my 82 Vanagon diesel. I custom built the harness, swapped everything over from the Jetta. The fit and finish look great, but the engine just does not idle right. It starts right up every time and it will idle fine for a few minutes when cold. But as it starts to warm up the idle starts to jump around. It will stutter for a few seconds then the engine corrects itself then it stutters again and then corrects itself, it will keep doing this.
I have no faults in the ECU. I have checked compression and all 4 and are at 350 when cold. I made sure my timing was right in the middle with vag-com. I pop-tested the injectors when with an amazon injector tester. They seem to be popping at 250bar as stated on the injector. The patter seems to be ok but I can't say for sure. One thing that I don't like is the injection quantity. It's very unstable, it bounces between 2 and 5 constantly. Also, my MVB13 shows my injector adjustments all over the place.
Here are some videos I took while connected to the VAG-COM. Its a video of MVB 1,13 and 8. I hope this helps to understand the problem I'm having. You can here the engine idle in the background and see the numbers change.
Part 1- https://youtu.be/CHFtDYpuryU
Part 2- https://youtu.be/0p5xYxQ95X8
Part 3- https://youtu.be/ooKXk7-jBPU
Thank you in advance for your help.
