Fiat500Baja
Hi, newbe here and am shopping for a 96-2003 tdi car as a donor for my project. ..what is the difference between the 96-98 and the 99-2003?...I was told that I will need to use the dash in my swap cuz the ecu communicates with the dash...is this true? ...I'm installing a TDI into a baja chassis. ..I already bought a aftermarket GPS speedo with a built-in tach. ..was planning on calling fast forward automotive for the tach conversion. ...I'm learning this stuff here on this forum...just wanting to know what parts I will need to salvage from the donor vehicle.
As stated in my introduction post, I'm looking to do a stage 3 setup, something around 180hp tune. ..also, where do you find the 4 bar map sensor and did the early TDI'S have one?...just thinking ahead for future power adders.
Thanks in advance...I will have more questions later on I'm sure.
