I recently converted the van from BLS to ASZ
I swapped the camshaft hub, done the mod on block for the crankshaft sensor, swapped- turbo, injectors, egr, egr cooler, vacuum pump, I left the ASZ oil housing in as the BLS wouldn’t fit.
I fitted new filters and belts,
The car will crank but not start,
Won’t start on bump and nothing with eazy start! ..
Any help is appreciated! Thanks
