sisyphus
- Joined
- Dec 8, 2008
- Location
- Appleton, Maine
- TDI
- 99.5, '01 A4 Jetta sedans, 5 sp box, Hamman mod, Joey mod, Bilsteins, 2.00" lift
So I've been chasing this noise down for a month or so now. When coming to a stop or slowing down enough to shift weight to the front of the car I hear a clunk, just one, from somewhere on the left, and fairly high up I think. I had guys at work today listen while I went back and forth in the parking lot.
When I speed up again or leave from a complete stop I'll hear it again.
I've replaced the strut bearings and the control arms w/ bushings, the stabilizer bar bushings. I've also gone under the car just last night and tightened up the subframe mounting bolts and the inner CV joint bolts. I'm at my wits end here. I have no idea what it could be outside of a bad motor mount but IDK how to diagnose that.
Should I check wheel bearing or something? The ball joints were done when I did the LCA's, not very long ago at all and it did it then, too.
