wcelliot
In trying to determine if an aftermarket chip set was part of the problem with my low power issue, I was trying to identify the chip.
What I found were two identical looking AMD chips (same serial numbers, etc) similar to the cheap Ebay chips I see.
I also note that the instructions say that one chip socket is low and one is high and the right chip needs to go in the right sockets.
So two questions...
1. which socket is which (identification seems to defer to the chips rather than identifying the location of the socket and I can find no pix of the stock numbered chips in their respective sockets... so if I wanted to swap back in stock chips I still wouldn't know which one went where) and
2. How would I know if the lo and hi chips were reversed? Could that be part of my issue? Or if reversed would they damage the ECU and/or not run at all?
Thanks!
Bill
So two questions...
Thanks!
Bill
