Hi,
I have a 2005 vw golf mk 5 1.9 tdi (105) and I've had this issue of grinding in first since I bought it. The car has currently done 133k miles.
Basically what's happening is that when your coming to a junction and your slowing down, I will put the car in first but will make a grind noise. This noise won't happen when I'm at a stand still.
Before I take out the box and inspect, has anyone had anything similar to this previously?
I have a replacement gqn gearbox at home from a vw touran 1.9 if need be but is a 6 speed as mine is a 5 speed.
What would be the best option to do? Change gear box or inspect for damage on current box? Also if I do go down the route of swapping gearbox to the gqn, would there be a parts list on parts which need to be changed like gearbox mounts or drive shafts etc.
This is my first post so I apologise if I've missed anything out.
