Thanks for the link. I have an 09 TDI and last weeks heat made my AC act up. When it works great. All of a suden hot air blowing, it is not a fan issue. VCDS show .825 specified but no actual on compressor amperage, that would be the switch, right. My switch is the snap ring style. Also if I evacuate R 134 won't the oil stay in the compressor? I am assuming this can be exchanged with compressor on the car.
Cooling dropping out in the first high temps of the season is very often low charge. As the temps increase, the pressure required to condense refrigerant vapor back to liquid goes up (pv=nrT, standard gas law stuff) and if the charge is 'on the edge', you will hit a point where charge volume is so low that the system can't get to that pressure, and this happens, and it's like flipping a switch to off . . . I had a Volvo that would do this every three years or so . . charge it back up, and good for 3 more years, and not worth tearing in to find the leak, since it only cost be a buck or two to restore the charge . . .
Often, when this is the case, it first quits when coming to a stop or driving slowly, due to less cooling air over the condensor than when at speed, coupled with lower compressor shaft speed . . .
Oh, and unless the RCV sits on the bottom of the compressor in the oil sump, you should *NOT* lose oil charge on an evacuation, and putting a full oil charge in thereafter may oil slug and destroy your compressor! Most shop manuals have a specific quantity to add when a component is replaced, and short of a full system flush and a new dry compressor, you pretty much never add the initial charge . . . it's almost impossible to get it all out, even if you try, without a compressor replacement!
