williamgd2
I have a blinking glow plug light again and car runs and drives fine but I know it could be a little better and vag com is claiming no fuel getting to the injectors any thoughts or should I contact ross tech support?
Thursday,23,May,2013,21:43:45:48274
VCDS Version: Release 11.11.5 (x64)
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 906 019 CM HW: 03L 906 022 TS
Component and/or Version: R4 2,0L EDC G000AG 7967
Software Coding: 0050078
Work Shop Code: WSC 08092 444 32768
VCID: 78F42D660B6FD9D819C
4 Faults Found:
000611 - Fuel Injector #1 (N30)
P0263 - 000 - Contribution/Balance Fault - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: -90.0°C
Temperature: 35.1°C
Inj. Quantity: 0.0 mg/str
Bin. Bits: 0000000
000617 - Fuel Injector #3 (N32)
P0269 - 000 - Contribution/Balance Fault - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: 35.1°C
Bin. Bits: 0000000
000626 - Fuel Injector #4 (N33)
P0272 - 000 - Contribution/Balance Fault - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: 35.1°C
Bin. Bits: 0000000
000614 - Fuel Injector #2 (N31)
P0266 - 000 - Contribution/Balance Fault - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: 35.1°C
Bin. Bits: 0000000
Readiness: 0 0 0 0 1
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: 35.1°C
Bin. Bits: 0000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: 35.1°C
Bin. Bits: 0000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: 35.1°C
Bin. Bits: 0000000
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 139085 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.77 V
Temperature: 35.1°C
Bin. Bits: 0000000
