I agree that the Blower Resistor is One Odd and unusual Part, case in point below.
I had to replace the RCV (2nd time) Valve in my compressor last fall, pulled a Vacuum and weighed in the exact amount of Freon. I was getting the air temperature from the 2 vents on each side of the car to make sure the Discharge Temperature was cold enough.
This was the Confusing part; while I was charging the system, I had the Fan on Max speed setting 4 then pressed the button from Fresh Air to Cabin Air to get a Lower air temperature. To my surprise the Temperature began to Get Hotter, if I put on Fresh air it would get colder. Especially if I slowed down the Fan Speed to #2 it got ice cold, but would get Hotter on Cabin recirculation.
I began checking out the Fan and when I touched the blower resistor it Literally Burned my Hand! It was So Hot that it was Heating Up the Cold Air that it was Circulating!
That was the Original Bower and Resistor that was in the Car New from the Factory 175K miles ago.. I would Never have thought that Anything could have gotten that Hot without Blowing a fuse, Over heating the wires at least?
Old Rattler, I'm like you and let the Fan Speed stay in the same Spot 99% of the time..
The Blower Resistor can act like an Emergency Heat Bank on a Heat Pump! That Can get HOT!!! Would you say it is the Resistor or Blower that's causing it to Heat up like that?
I have been told by a mechanic that USE to work on my Car sometimes, that there are 4 Different Grades of parts available for our TDI's.
The 1st are OEM, the 2nd are made by the same factory that supplies the OEM parts to VW, the 3rd are made in Mexico (that's where my car was made) and the 4th and Least expensive and Cheapest are Made in China.
