Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Other TDI/Diesel Picture Gallery
Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old March 14th, 2017, 11:08   #31
nokivasara
nokivasara's Avatar
Fuel Economy: 44-49 mpg
Did an oil change today, holy cow is that OEM steel skid plate heavy and awkward to get back up
Also checked that the wheels weren't about to fall off and that I had some tools and plastic tie strips in the car, along with a snow shovel, jumper cables and other good to have stuff. I never take them out during the winter but you never know
I'm heading up north, almost to the arctic circle, got to be prepared for the worst in case I get stranded in the middle of nowhere.
nokivasara is offline   Reply With Quote
Old March 14th, 2017, 11:41   #32
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Happy travels and stay safe!
2010 4D CWhite Golf TDI, 6 sp manual, Bixenons, Rear Airbags, RNS-510, Dynaudio, DieselGeek SS & P2015 bracket, Force Fed Eng. Shifter Bushings. XB,UB, & RB UNIbraces; TyrolSport Brake Caliper Bushing, 2Micron Contain/PureFlow kits, PolarFis MFD module, Euro light switch, R Red LED Tail Lights,Under Seat Drawers, Full color MFD cluster.
bobt2382 is offline   Reply With Quote
Old March 14th, 2017, 12:35   #33
nokivasara
nokivasara's Avatar
Thanks, I'll post pics if I see something interesting. Like reindeer or northern lights or something.
Most likely I'll only see trees, trees and more trees!
Old March 20th, 2017, 14:15   #34
nokivasara
nokivasara's Avatar
I'm back home after 5 days, 2240km and 130 litres of diesel = 5.8l/100km.
Here's a few pics:
Arctic circle, the car is facing to the north (in case someone wonders how the sun can reflect from that direction)
On this one you can see over the border to Finland, the river is the border. No fences or walls :
Straight roads and some scenery from the north of Sweden:
Old May 6th, 2017, 12:11   #35
nokivasara
nokivasara's Avatar
Changed the oil and filter in the Haldex unit, found quite a lot of crap, but what is it?
RTV sealant?
Lastly a picture of the peculiar design of the OEM exhaust system. That pinched section is not pretty.
Old May 15th, 2017, 11:29   #36
nokivasara
nokivasara's Avatar
Replaced an indicator bulb, the whole headlamp assembly slides out. It's not hinged, I just put it in like that to be able to snap a pic
Old May 17th, 2017, 08:58   #37
nokivasara
nokivasara's Avatar
Another picture from my "office".
I almost stepped right in to a bear's den today, they aren't in use during summer so no worries
Old June 11th, 2017, 10:36   #38
nokivasara
nokivasara's Avatar
Today I flipped the mounting plate for the led light bar. It does worsen the beam pattern when you have the light near the ground but the light bars aren't that impressive anyway so it'll do for now. The plate is attached with 8 screws, not only those 2 in the picture!
I have also swapped wheels with a fellow Octavian ( ), he took my 17" VRS wheels and I took his 15" stock wheels, they are called Pyxis I think.
I drive a lot on gravel roads and the 15's are much better for the car, a lot more air and rubber between the rim and the road.
Then I have prepared for a flywheel replacement, bought Sachs flywheel, clutch and pressure plate.
Last edited by nokivasara; June 18th, 2017 at 08:24. Reason: Broken links from photobucket...
Old June 11th, 2017, 14:12   #39
bobt2382
bobt2382's Avatar
Fuel Economy: 46.5
Nice. Smart move on swapping the wheels. Give us a side pic next time you post so we can see the new wheels, lol.
Old June 16th, 2017, 08:35   #40
nokivasara
nokivasara's Avatar
Really happy with the wheels, no pics last time because I just remembered that when I posted the other pics. Here's a picture from todays adventures:
Old June 23rd, 2017, 13:13   #41
nokivasara
nokivasara's Avatar
Tinted the windows with static cling tint, it's OK from a distance
octavia 1.6 tdi kylobeddo General Automotive 0 August 14th, 2014 06:50
2008 Jeep Laredo 4x4- trade for a TDI! TDI_01 TDI Cars for Sale/Wanted 7 October 27th, 2010 14:42
octavia tdi goes nuts far_cry TDI 101 4 December 30th, 2009 13:18
Car and Driver: 2008 TDI Jetta named one of 2008's most fuel efficient surprises Tahna Los TDI News/Tech 162 February 3rd, 2008 14:50
Skoda Octavia TDI's Stateside? Arcturus VW MKIV-A4 TDIs (VE and PD) 9 June 7th, 2000 02:02
Page generated in 0.15612 seconds with 12 queries
[Output: 110.60 Kb. compressed to 93.48 Kb. by saving 17.12 Kb. (15.48%)]
