Hi All,
I lost time on my MK3 1Z engine due to a previous owner re-using the crankshaft stretch bolt. I am working with a local mechanic to put this all back together and could use some guidance on the plan.
For the head, the lifters are being replaced and my very rare 8mm valves are being replaced with 7mm Intervalve intake/exhaust valves and OEM valve stems. The machine shop says this can be accomplished by just replacing the valve guides. The camshaft looks ok, but I am putting in a brand new OEM replacement just to be safe. I had a temporary detour by purchasing some 8mm valves from a German shop that don't fit and it looks like I will probably have to eat that cost.
I am planning to buy the replacement harmonic balancer (028 105 243). Mine is definitely the old style without the rubber on top. I'm looking at eBay listings and some say Febi is the OEM and others say Vaico. Which one should I buy?
I have records the water pump was replaced very recently, so I'm going to skip that. We have the old timing belt, but will be putting a new one on along with idler roller and tensioner roller.
Can the head bolts be reused or is there any value in buying new head bolts?
One of the howtos mentions replacing the tensioner rod and the serpentine tensioner. Do these affect the timing belt or engine operation? Can I replace them by myself later?
The last part that concerns me is that I do not have a working computer interface. There is power to the OBD port, but some connection issue. I have tried generic OBD scanners and a VAG-COM. The mechanic is mentioning to time it without VAG-COM. He is a skilled mechanic, but not a TDI guy.
Is there anything else I should be concerned about or parts to replace or check while everything is still apart?
h.ubk
h.ubk
