Old March 24th, 2017, 22:28   #16
burn_your_money
TDI(s): none
Originally Posted by wonneber View Post
What seal is the 'main seal' ??
Is there a common one that could leak air in?
Only one will let air in and that's the mainshaft seal, which is the hardest because you have the remove the hub pulley, or more accurately, put it back on correctly.
burn_your_money is online now   Reply With Quote
Old March 25th, 2017, 09:19   #17
skyking1
OK, I fixed my issue. As embarrassing as it is, I will tell you what it was..
When we did the clutch job, we pulled all sorts of parts out of the way. I had failed to properly install the engine end of the air intake duct. It had wiggled off and was replicating the same symptoms of a lazy MAF sensor. It would butt up tight now and again, and let me have that good pull. Then it would leak air and throw off the MAF output and cut fueling.
skyking1 is offline   Reply With Quote
Old March 28th, 2017, 12:29   #18
Nevada_TDI
You are not the first to have that happen, and I am sure you will not be the last. Glad to hear you found the problem.
_______________
2001 Jetta GL TDI, 35/15% Tint, Ventectomy, Catectomy, EGR-ectomy, Stage 4 TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
FS: VW Golf TDI Aluminum pedal kit plus dead pedal walden Private TDI Items for Sale/Wanted 4 January 12th, 2017 08:52
Mk6 Golf Projector/ HID, Gauges, Aluminum Pedal(inc. Dead pedal), Hatch pop kit frcefed Private TDI Items for Sale/Wanted 12 May 5th, 2013 02:17
:: ECS Tuning :: ECS TT Pedal Sets and Dead Pedal - Free Shipping !!! ECS Tuning Vendor & GroupBuy items for sale 14 December 29th, 2011 13:57
:: ECS Tuning :: OEM Mk4 R-Line Pedal Set and Dead Pedal - Blowout Pricing !!! ECS Tuning Vendor & GroupBuy items for sale 18 March 16th, 2010 08:04
Audi TT pedal set w/ dead pedal $80 shipped TdiRacing Private TDI Items for Sale/Wanted 4 December 6th, 2007 00:29
Page generated in 0.11616 seconds with 12 queries
[Output: 58.46 Kb. compressed to 53.16 Kb. by saving 5.29 Kb. (9.05%)]
