KeithOfOhio
Was driving up a steep climb to a low pass and experienced severe reduction of power, smoke out exhaust, and a squeal followed by a rattle that sounded like a bearing failure. The car will drive a short distance while smoking with the noise intermittent. I installed a tow hitch and towed the car home for repairs. Here is the car's background:
May 2001 VW Golf 1.9L TDI 5sp manual ALH 148,000 miles with VNT15 turbo
Other than timing belt replacement, no major till recent when a valve lifter wore through. Replaced were the valve lifters, #1 intake valve (need to check for proper install height), camshaft, oil pump, oil filter, and engine oil.
Car operated just fine and I started making trips back and forth over a low highway pass. At roughly 300 miles after major, the car objected profusely during the final stretch of reaching the 1,000' summit. {I know Californians, this is a bump compared to your 11,000' high passes.} This would be the time the turbo would be in full load as the pass is very steep {think its 7% grade).
My car starts fine, it smokes bluish, lacks power but still mobile in terms of yards, and gets noisy as it warms up with an intermittent squeal and also rattle sounding like a turbo bearing failure. I popped open the valve cover finding no problem, compression testing is 595/590/595/595, and climbing underneath tracking the noise led me to the rear of the engine around the turbo. A sound probe indicates the noise is mainly emitting from the compressed air side. Taking off the turbo oil return line resulted in only a dribbling of oil coming out while the engine was running when I expected a steady solid stream.
This forum has write ups on removing the turbo either from atop or two ways from below. However, there is little regarding troubleshooting and options. I figure the N75 and MAF are not an issue since they would lead to the squealing/rattling noises. I did find a 100K used turbo with all auxillaries and oil supply line attached and including shipping available for $400. A brand new bare bones turbo is $800 then add shipping. Here are my questions I hope some of you can timely answer (June 2012):
July 2012 update with turbo problem found -
Replies confirmed suspicion the turbo had failed also saying the causes are rarely known.
Replies identified the VNT15 is a journal type versus the ball bearing type so not repairable.
Replies mentioned that lack of sufficient lubrication or foreign debrie is the common failure cause.
Replies mentioned once back in operation there would be lots of smoke as oil in intercooler burned out.
Removed the old turbo finding its shaft broken and the compressor side blades a bit mangled. I obtained the 100K mile used turbo and installed it. Part of the install was to replace the hard oil feed line with a flexible one, remove the troublesome and somewhat useless EGR apparatus, and test turbo oil supply line flow. AHA!!! The flow was a dribble; insufficient for adequate lubrication. Problem: In the short 300 miles after top end work noted above, the 5 quart engine oil had lost 3 quarts without any warning. Being I have been using a high quality synthetic (AmsOil) and B100 (high lubricity), the rest of the engine seems to not have been harmed. After adding 3 quarts, the turbo oil flow was as would be expected. No leak can be found onto the ground can be found. It going somewhere!!!
During teardown, a cup of oil was removed from the bottom of the intercooler and it was mentioned the car would smoke billowing for a while. True, it sure did, and it took 20 miles on the highway during a downpour for me to clean out 90% of the intercooler contamination without donating to the local Christmas fund.
