james290179
Guys
Ive had a bad run trying to fix my 1.6 tdi cr cayc
Ive replaced maf glow plugs 1 injector and now my misfire problem seems to be related to the g851 vane position sensor implusible signal
Ive vac tested it and it holds ive traced it back to this valve
When i start the car the presure reg valve n75 applys full presure to the actuator and the car runs rough misfiring. If i unplug the n75 car ticks over ok
I presume when the car is started the turbo actuator shouldnt move and the n75 us closed
As turbo speed increases the acuator moves vanes in thebturbo accordingly
Ive 12v at the n75 could someone confirm the actuator doesnt move fully on start up
Dont want to buy more unnecessary parts
Many thanks in advance
