charger per 330d 3000cc diesel, per avere +400hp
mao76
italia
vw lupo asz 130cv
I have a 330d e46 6 cylinder 3000cc diesel engine, the car charger gt2260v elaborate 340cv fact, I would like to replace with a bigger charger to reach 400hp, but without losing too low, what do you recommend?, thought gtx3071r
2slowtdi
Dallas Tx
2003 ALH Bora gone. 2006 Benz CDI 235hp 420ftlbstq
Not to many people on this side of the pond that have the parts to make power here on BMW diesels.
The Finnish have made Big Hp from the Benz's.
BMW has only been here a few years and most still are under warranty.
mao76
italia
vw lupo asz 130cv
know something about these mercedes, that charger have on their vehicles?
DnA Diesel
Ottawa, Ontario, Canada
no more...
It may not be possible with just the turbocharger upgrade...I think you will have to increase the rail pressure, and I'm not sure the existing pump can maintain pressure at that horsepower level. 400hp is almost double the E46 M57's original power rating. You may have to upgrade from the CP3.2 to the CP3.2+ pump to maintain sufficient rail pressure at the higher fuel flow.
Regards
D.
mao76
italia
vw lupo asz 130cv
gasilio and 'enough to 400hp, the air flow rate of the charger and that' insufficient,
diffas
Finland
B5q A4 Avant 2.5TDi+, B7q A4 Avant 3.0TDi
Buy yourself and upgraded 40/35d twinturbo-set.
mao76
italia
vw lupo asz 130cv
bmw 335d charger mean?. I do not understand. I have in mind a gtx3071r
diffas
Finland
What do you don't understand? With 35d engine twinturbo package you can have 380hp.
With wastegate turbo you can have that power but it's gonna be laggy on revs. Other option is make custom vnt of your current putting bigger wheels inside stock housings. Lots of options available :D
mao76
italia
vw lupo asz 130cv
ok, I have a bmw 330d not 335d, can not manage twincharger, gt2260v with bigger wheels does not make more than 340hp, now I'm focusing on a gtx3071r,
TDIMeister
Phd of TDIClub Enthusiast, Moderator at Large
Canada
You will have problems going from a VNT turbo to a wastegated GTX3071R one because the method of control by the ECU is very different. You could investigate putting the GTX3071R cold side on the existing turbine or a slightly larger VNT one.
mao76
italia
vw lupo asz 130cv
gtx3071r impossible to put a cold side of a VGT, bigger than just gt2260v he351ve Holset, Garrett gt3571vgt, but 'too big, too small gt3063vgt
diffas
Finland
There is no problem controlling wg turbo. Put on external or internal waste gate. Boost controlling from intake manifold and using map for controlling fueling.
