The saga continues....
Finished replacing the brake booster in the 02 Jetta. Used the Motive Power bleeder (dry) to bleed all four wheel cylinders and the clutch.
For the record, I pumped the Motive up to between 10 and 13 PSI each time and never let it fall below 10 PSI.
I bled the clutch first, and accidently ran the resevoir below the minimum mark Got a lot of gurgles and tons of bubbles.....Oooops. Anyway, refilled the resevoir and re-bled the clutch twice. Disconnected everything and pumped the clutch pedal about 50 times (no kidding) good clutch pedal, so I proceeded to the brakes.
Bled in sequence LF, RF, LR, RR since the car is a later model Mk4. The fronts bled fairly easily and I got lots of clean fluid with no bubbles in my clear bleeder hose. So far so good.
On to the back. Bled both of them the same as the fronts, but they bled really slowly. Finally got clear fluid with no bubbles, so I closed everything up.
Started the car and the clutch felt good. After idling for about a minute, I got no brake or ABS indications, so I tried the brakes. The pedal was really soft but after about 2-3 pumps, it firmed up.
Now the bad part(s). Each time you hit the brakes, the pedal seems low and a tad soft, but if you tap it again, it gets firmer but never as hard as before the booster was replaced. However, if you keep pressure on the brake pedal, it now slowly sinks to the floor! If you let up on it and tap it twice, it gets semi-firm again, but with constant pressure, it slowly (about 10 seconds) sinks to the floor.
I shut the car off, and tried the standard booster check. I pumped the pedal 3-4 times and it got really firm. Holding pressure on it I started the car and it slowly sank, just like a good booster.....except it kept slowly sinking.
SO....What did I do wrong or what is the problem? I'm thinking air still in the lines somehow, but I did what I thought was a really good bleed.
The rear emergency brake was on the whole time I bled the rears, could that cause a problem?
I guess I'm looking for educated suggestions as I've done plenty of brake jobs before (just not on a VW) and never got the dreaded sinking pedal.
Should I bleed the brakes again with the Motive? Should I do it the old fashioned way?? I never bled the ABS unit as I don't believe it went dry, and I only disconnected the two Master Cylinder lines when I replaced the booster. According to my Bently, and Ross-Tech, the ABS unit needs to be bled only if it goes dry.
If I need to bleed the ABS unit can I do it with the Share version of Vag-Com, or do I need the full blown version?
Thanks for any help,
Glenn
Glenn
