Tdipickup
Calling modified alh experts! Been chasing a low power issue on my alh setup. I will list off the mods and what I have diagnosed/changed so far.
ALH engine with 17/22, r520's 11mm pump, lift pump, race pipe intake, 2.5in exhaust straight through, fmic, software, etc.
Problem began about 6 months ago, when it felt down on power. Also egt's were excessive, reaching 1600 in under a 1/4 (It could go a 1/4 and then some before this temp was reached before this issue). Camshaft was then upgraded to a colt stage two and lifters were changed, but no significant increase in power or lowering of egt's happened. Everything I have checked has come out positive.
Timing is perfect, iq is set at 3.8, boost is at what the chip calls for (27 psi).
I believe the issue lies somewhere in the fueling system, as the air is there. Changed filter and inspected lines, no change. No leaks on injection pump. Injectors seem fine, no symptoms of a bad one. New case pressure valve in injection pump. N108 gave acceptable ohm readings. Occasionally when giving it a hard run, an error code will be thrown, 00550- Start of injection Regulation
17-10 - Control Difference - Intermittent. However, this code is unpredictable in terms of you can not force it to happen by doing one particular thing.
Only discrepancy I could find this the start of injection timing on a hard pull, as graphed here
One shows expected and one shows actual degree of the injection, this data came from measuring block 4 if I do recall correctly. Other than the error code and this graph which I cannot make any meaning out of, I have no other leads. But there is an obvious problem when your trap speed goes from 98 to 74 mph! Thanks
