AutobahnTDI
What/where is the clutch reservoir? I am confused... did he not he bleed the clutch?Nice write-up. You should have flushed the clutch res. while you were at it--kill 2 birds with the same messy stone.
I am interested to know if you will be making any updates. I am doing this soon and I want to do it right. thanksI did bleed the clutch, but I forgot to write it up. :-/
When I do it again, I will include the clutch bleed and take some new pics. The write up could use a little tidying anyways.
Can anyone elaborate on this? I'm not following this.Also, when removing the old fluid from the reservoir with a turkey baster, don't forget to remove the screen so most of the old fluid is removed.
I have not seen any other discussion debating this. For a 2003 MkIV, some say to proceed RR-LR-RF-LF, while others (MoGolf) say LF-RF-LR-RR. Which is correct?? Could it be that both methods are acceptable, though one pattern might be more desirable??<font color="red"> Oh, one other item: MOGolf reports that 2001.5 cars and newer use a non-traditional pattern meaning it is reverse of the pattern most of us are accustomed to. Start at the nearest (clutch) and finish at the farthest point (RR).</font>
My Bentley Service manual says if you are replacing brake fluid:paramedick said:You bleed the clutch because it is a hydraulic system, and shares the same reservoir as the brakes. So all the bad things that can happen to brake fluid will happen to the fluid in the clutch, too. Go ahead and bleed it. Just be aware that you have to pump the pedal while bleeding it.
As far as what method is best, it really doesn't matter. I have done it both ways. Most folks just fill the Motive because it is easier. If you use the reservoir method, be sure to keep a close eye on the level in the reservoir to prevent air from entering the system.
The Bentley manual makes a big deal of pointing out that Jetta & Golf years 99-01 (on page 45-4) have the Mark 20 break system (and are bled RR,LR,RF,LF) and years 02-05 have Mark 60 (bled LF,RF,LR,RR).cosmic said:Thanks for the responses. I am happy to give something back.
GeWilli - Certainly Geoff you can make it into a pdf, although it looks like twojettas beat ya to it. I finally used your ventectomy pics last night, to yank my vent button.
Dieseldorf - I noted that Bentleys said to NOT exceed 14.5 psi (1 bar) so I stuck to that rule. Things might work a bit faster with higher pressure, but it was a nice day.Thanks for the info on the rear brakes being softer. There are just under 45K miles on the car. Regarding the pattern, once again, bentleys said RR,LR,RF,LF. I actually ended up doing RR,LR,LF,RF then clutch. I guess I just got going around the car...My Jetta is an early 2001.
Gulfstream - new pads and rotors for the rear are on the way from Impex. I was already grinding on the rotors just a hair, and Impex has rear rotors on sale, 2 for $40.
Thanks to all and feel free to use the info and these pics as you please.
I am so confused now...hutchman said:The Bentley manual makes a big deal of pointing out that Jetta & Golf years 99-01 (on page 45-4) have the Mark 20 break system (and are bled RR,LR,RF,LF) and years 02-05 have Mark 60 (bled LF,RF,LR,RR).
The part that gets me is the section that talks about replacing the break fluid (page 47-16) does not mention the type of break system and says to start with clutch then RR,LR,RF,LF. I wonder if this is a mistake????
That seems to be odd. It's my understanding that the 99-01s do RR,LR,RF,LF,clutch. I would think that the 02-05s would do clutch,LF,RF,LR,RR.hutchman said:The Bentley manual makes a big deal of pointing out that Jetta & Golf years 99-01 (on page 45-4) have the Mark 20 break system (and are bled RR,LR,RF,LF) and years 02-05 have Mark 60 (bled LF,RF,LR,RR).
Actually, I think the brake fluid will come out, but potentially in places not intended. YMMVhutchman said:The comment about 14.5 psi says that if you use higher pressure, not all of the break fluid will come out.
