eddieleephd
Running a Malone Stage 4 tune and 1019 nozzles Garrett VNT 17 turbo and 11mm pump
After running a single mass flywheel for a year and loosing 5th gear I decided to go back to a dual mass flywheel and get rid of the chatter.
Trying to Figure out if I should run the LUK clutch pressure plate and pad, or go back with the SB pressure plate and pad. I guess I assume that they are even compatible, are they?
Not sure what the best option is here, obviously. Just tired of the chatter and curious if anyone has good information to share about this predicament.
Code:
j. Driveline
1. Clutch
For the A3 and B4 cars, if an upgraded clutch proves to be necessary as a result of engine upgrades, the VR6 clutch assembly is a direct replacement, and any aftermarket clutch that is suitable for a VR6 application is also suitable for a TDI application.
For the A4 cars, a VR6 or VR6-compatible clutch assembly can be installed if the flywheel is replaced with a flywheel from a 4-cylinder G60 engine.
Upgraded clutch parts are available in the USA from www.dieselgeek.com and elsewhere.
Back to Top
2. Final drive and differential
The weakest link in the O2A (for A3 and B4 cars) and O2J (for A4 cars) 5-speed manual transmissions involves the final drive and differential assembly. Vehicles with performance engine modifications, which may experience hard drag-racing-style launches, wheelspin that results in wheel hop, and similar actions which place the greatest stress on the final drive assembly, should have the final drive and differential upgraded to reduce the chance of having problems in this area. Quaiffe or Peloquin final drive units employ a "torque biasing differential" that improves grip in slippery conditions while eliminating the spider-gear cross-shaft which is a weak point in the stock differential. These final drive units should be bolted to the final drive ring gear with high-strength bolts, usually available as part of the final drive kit. Installation of such components is best left to experts in manual transmissions.
Be aware of the possibility that some earlier models may use a different style of half-shaft mounting arrangement compared to other models that use a similar transmission. There have been a few situations where apparently the half-shaft mounting arrangement of an O2J transmission was found on what is otherwise an O2A transmission. Consult with experts in VW manual transmissions, such as wherever you intend to purchase the unit from or whoever you are planning to get to install it
