So my friend recently picked up a 2003 Jetta TDI with 199K miles on the clock. It has a lot of mods done to it, but this is going to be a fuel sipper for him.
Right now it has an older Rocket Chip stage 3 and 5spd nozzles. It had an 01M auto trans but that was swapped out around 180K miles according to the PO. And the timing belt was done around 170K miles / Aug 2010.
But the turbo is leaking oil pretty bad. The outlet pipe to the intercooler is dripping with oil. So instead of buying a new turbo, my fiend would like to go with the Malone Stage 0 tune.
So I'm looking to compile a shopping list / to-do list and to help him do this.
The end goal is to make this no more expensive than a new VNT-15 turbo with install kit and potential replacement feed/return oil lines.
Intake: Is it better to get a drivers side PD intake or should I shop around for an SDI intake manifold? Who knows where I can pick up an SDI intake or order one from? My friend has a diesel geek race pipe sitting in a box that the PO never installed. Probably because he was worried about run away with a leaky seal in the turbo.
Camshaft: Should this be swapped out? Which one should to get from what model engine? Or would it be OK until the timing belt is done?
Exhaust: What year/model 4cyl VW should I look to acquire this from? Is there something that will bolt up to the down pipe? Or at least something that will bolt up to the cat-back section?
Fuel system: Cat 2 micron fuel filter, 5-spd nozzles, and 11mm pump. Is this a good combo? Or should the nozzles be changed out to down size them to the auto nozzles? Would a PP357 be a better good choice?
Things to delete / remove and questions about the Malone Stage 0:
Did SDI's have EGR systems? Does the Malone Stage 0 remove it and it is a matter of blocking things off? What do to do about the vacuum valves / lines?
What to do about the VNT actuator / valve line?
IMMO delete might be a good idea.
Would a dynamic idle be good with this? Does anybody know what the normal warm up time is for an SDI / Stage 0 when them temp is around 0 degrees F?
I might have him keep alll of the parts and everything removed just in case he hates the non-turbo feel of the car. So I might suggest he also buy a spare ECU to have done up with the Malone Stage 0.
And when removing the turbo, what size fittings will be needed to block of the feed/return oil line ports?
Any ideas as to what the fuel economy will be once this is done? My friend is ok with it being slow and not so peppy. He hopes going up 7%-12% grade hills will be smooth, maybe worst case 3rd gear to maintain 50mph?
Depending on how well this goes, I could see changing out the transmission in the future? Or re-gearing it? What gears ratios do the SDI's have? What about going with a gasser transmission and then installing the 6th-gear ad-on kit from a couple of vendors and selecting a decent highway 70mph overdrive gear?
Lastly, does anybody know if anybody on the forum has done a stage 0 tune? I searched, and only saw a few references to it and the vendor thread with an engine that might be getting a super charger.
Thank you,
My friend is waiting on moderator approval for his account. So he will jump in here soon.
~ryan
Thank you,
~ryan
