0die
The pax side wiper has always sucked...doesn't make full contact across the glass, in the middle/main area I mean, not the edges...
Replaced wipers with those new fancy beam blade types...you know, those expensive high tech looking ones that all the new cars are using...supposedly better, more uniform contact...
well they sux just as back on the pax side...only the pax side...driver side is fine with old style or new style blades...
what gives...I have a theory that the spring/tension of the pax wiper arm is weak and not pressing the blade enough to make full contact...
Or is the pax blade supposed to be a different size? thus the curve is incorrect for the sweep area?
