Old May 18th, 2010, 12:25   #1
dae06
dae06's Avatar
Default Lights stay on and can not unlock doors without key FOB
When I pull into my garage and leave the keys in the ignition, the driving lights (?) never shut off. Can a VAG COM program lights to shut off after a certain amount of time (with the keys in the ignition)?
Also, quite often I need to open the trunk or unlock a back door. I open the front door and lift on the door unlock switch on the door, and nothing. I end up having to get in the car, get the key FOB and unlock it this way. Is this normal? Why don't the door switches work to unlock the rear doors or trunk after a certain amount of time (after the car has been shut off)?
I mean, really. The lights will stay on until the battery dies, but the unlock switches disengage so I can't unlock a back door or trunk. I want just the opposite; Lights that turn off after say, 20 seconds and door switches that are active all of the time.
Solutions and explanations as to why the car is designed like this are appreciated.
2005.5 Jetta 1.9 TDI, Manual Transmission.
206,000 miles as of 11/14/2017; New Cam and TB as of 12/1/2014, New EGR valve and EGR cooler as of 3/29/2016
dae06 is offline   Reply With Quote
Old May 18th, 2010, 15:21   #2
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
2005 Jetta as in MKIV, or 2005.5 Jetta as in MKV?
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old May 18th, 2010, 17:02   #3
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
I'm going to assume it is the 2005.5 that is listed in blue under his fuelly banner.
Of course I know what they say about assuming.
Fixmy59bug is offline   Reply With Quote
Old May 18th, 2010, 19:11   #4
jonathantingley
Does the door only work when it was closed? mine was doing that when the wires were broken off, it would work when the door was closed, or even open a hair but if i opened it the door more it would lose power. The door locks and trunk release switch should always work.
as far as the lights staying on, just pull the key out and put it back in? not that big of a hassle
jonathantingley is offline   Reply With Quote
Old May 19th, 2010, 05:56   #5
dae06
dae06's Avatar
2005.5 MKV.
Only works if I turn the key on. Again this is only after the car has been off for a while. Any other car I had, all I needed to do is open the front door and unlock the rest from there. Now I have to get in the car, turn the key on and unlock, or pull the key FOB out and use the FOB to unlock. I don't think there is anything wrong. I think for some reason it is designed that way. Why I don't know.
Pulling the key: Yes, this is what I have been doing. It is a major pet peeve of mine though. When it's a bright day or I park outside, I don't see the lights and sometimes forget to pull the key and put it back in. Actually happened a day ago. All my other vehicles lights turn off automatically after a short time.
But really I wondering if there is there a way using a Vag Com to change these settings?
Old May 19th, 2010, 06:28   #6
jonathantingley
There is something wrong with your door. My mk5 doors always have power, no matter what. I can unlock the doors and pop the trunk at any time, ignition on or off.
You can configure it with vcds so that all the doors to unlock when you pull the key out, makes life a lot easier.
as far as the key thing, you might as well get used to it
Old May 19th, 2010, 07:55   #7
dae06
dae06's Avatar
Weird.
Do you by chance leave your keys in the ignition? I haven't tried this with the keys not in the ignition. I'll play around more tonight and see what I come up with.
Also, I am not sure how long the car needs to sit before they become inactive.
Old May 19th, 2010, 08:22   #8
Windjammer
TDI(s): MK4 & Mk5
OP, Turn off the engine pull the key out & put it right back in the switch & your lights will be off. It sounds like your car is working as designed.
00 Jetta TDI GLS Auto Black w/Beige leather, Phatbox
06 Jetta TDI Shadow Blue w/Beige Pkg 2 DSG W/NAV & Phatbox
06 Jetta TDI Blue Graphite w/Grey Pkg 2 DSG W/NAV & Ipod dock
06 Jetta TDI White w/Beige Pkg 2 DSG
06 Jetta TDI Black w/Beige Pkg 0 5MT
Windjammer is offline   Reply With Quote
Old May 19th, 2010, 08:23   #9
dae06
dae06's Avatar
That's what I have been doing, thanks.
Old May 19th, 2010, 09:49   #10
jonathantingley
I'm telling you there is something wrong with your door, my door locks ALWAYS work, key in/out, ignition on/ off.
Just pull the rubber boot back and check the wires.
Page generated in 0.13179 seconds with 10 queries
[Output: 96.93 Kb. compressed to 82.19 Kb. by saving 14.74 Kb. (15.20%)]
