Did everything I could think of on the front end suspensions of the TDI this weekend. With 160k on what looked to be mainly original parts it was pretty tired and uncomfortable to drive long distances. The lack of power was atrocious on the 8hr drive home when I first bought it. This is my GF car and I have a 350whp Passat Variant, so was night and day to compare the two.
Inner/Outer Tie Rods, Ball Joints, oem fr/tt rear bushings, strut bushing &bearings, all new hardware $180
Bilstein sport struts, front & rear, used $300
H&R race springs, $100
Hotchkis front sway bar, new bushing/brackets, $150
SS Heim joint end-links, $140
VF dogbone mount used, new bushings, $100
$10 for LCA bushing removal and install
$10 for welding both front LCA 'nuts'
One 'nut' broke free. Removed the sub-frame with one control arm attached yet. Drilled 5/8" hole below the nut/near the inner pocket wall. MIG welded the nut to the pocket wall.
We also cleaned the whole intake system. My GF actually did most of the work minus breaking loose bolts/dis-assembly stuff/hard to reach stuff. Disassembled all the piping from the air box to the cylinder head. Cleaned out any oil/soot/built-up crude. Removed EGR,EG cooler, ASV & EGR solenoids. Installed 'race pipe', OEM coolant by-pass line, block off plate. All new Forged silicon hoses replaced all the OEM clothed covered rubber. Freed up the vains in the turbo with little back and forth working of the actuator. Malone stage 1 tune was installed a few weeks ago, but we were not seeing any boost due to the stuck vains.
Working on acquiring a rear Hotchkis bar to match up to the front. Then driving the crap out of it. A few trips planned for family visits this fall. It drives and handles so much better.
