dweisel
FS Beetle door cards
Beetle door cards. Driver and passenger side. RED/TAN. These door cards are in above average condition. Plus these panels have the HARD INSERTS which will not sag like s many of the vinyl ones do. The grab handles were cracked so I bought and installed the aluminum repair handles. These handles will hold up for a very long time. I used QUIK STEEL to epoxy the aluminum tubes into the door card. This will make these handles very durable and strong.
To install these door cards just install as normal and the slide the provided handle torx screws through the tubing and screw them into the existing OEM handle mounting holes.
Two very small cracks on the passenger side panel as noted in the photos.Also someone had put two small screws through the driver side window switch to hold the switch in place. These small holes are covered by the switch trim once the switch is installed in the mounting hole.
Overall a nice set of door cards.
NOTE: See eBay pics for close shots of any known defects.
If you have any questions,feel free to ask.
For sale on eBay for $400.00 shipped. tdi club member price is $325.00 shipped.
Do not buy these cards on eBay. I'll post pics as soon as possible.
https://www.ebay.com/itm/323006463932?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
Thanks,
dweisel
Thanks,
dweisel
