My 02 jetta tdi is in the shop, I had the nozzles changed to titan .764`s , the clutch was changed to a stage 3 from bora with a Single mass Flywheel, I had the cat and muffler removed and welded to straight 2.5, a 3 bar map installed, and I had him install a custom stage 3 tune with the dynamic egr control. The Mechanic said he thinks the car can be tweaked a little more with some more logging because he feels as if the car can handle more Horsepower and torque. He said i could possibly get a stage 4 tune installed if he can get the .764 nozzles to flow enough fuel to run it. Any thoughts ? what should I do ?
I haven't driven it yet so I don't know how it handles with the stage 3 in it now. The turbo is stock turbo running 19 psi and 22 at peak boost.
And I also forgot to mention that he installed launch control as I was curious on how that would affect the off the line start times.
