Old June 12th, 2018, 16:41   #1
JLMurphy
Default Trying to confirm a bad alternator
Driving home today the battery light turned on in my '01 Golf. I checked the voltage when I got home and it's around 12.5V with the car running. I checked the large cable at the alternator and it has battery voltage as well.
I pulled the little connector from the alternator and with the key in run I measured ~11.5V on each pin.
I then pulled the belt off and checked the pulley, it seems to be nice and tight and the clutch seems ok.
At this point I'm thinking the alternator (or the regulator, which amounts to the same thing) is done.
Is there anything else I should check?
Jim
JLMurphy is offline   Reply With Quote
Old June 12th, 2018, 20:22   #2
Fahrvegnugen
Mine just went suddenly the same way, so I brought it to get tested and it gave no reading on FLAPS machine. I thought I could try replacing the regulator but it smells a bit fried. You reminded me to check the fuse. It's difficult putting a new one in without knowing what happened, but I think I will.
Fahrvegnugen is offline   Reply With Quote
Old June 12th, 2018, 21:58   #3
Vince Waldon
Vince Waldon's Avatar
Yes, if you're only getting 12.5V as a system voltage with the engine running the charging system has quit.
You can remove the regulator/brush assembly with the alternator still in the car... worth a check to see if the issue is simply worn brushes. They are a wear item and pretty common point of failure.
That said, good idea to check the slip rings too if you find short brushes... if the rings are deeply grooved as well no sense buying a new regulator/brushes; you'll want to spend that money on an entire alternator.
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
Old June 13th, 2018, 04:51   #4
Dieselmonkey02
TDI(s): 02 jetta
Fuel Economy: 48-50 avg. 44 lowest 54.6 highest
When my alternator died it went the same way, sudden battery light.
Dieselmonkey02 is offline   Reply With Quote
Old June 13th, 2018, 10:02   #5
JLMurphy
Well, since the car has 231,000 miles on it and I think the alternator is original (I've never replaced it and I've had the car since 80,000 miles) I think I'll just go ahead and change it out. Chances are the brushes and slip rings are pretty worn at this point.
Kind of annoying since just 2 weeks ago I replaced the clutch and flywheel and now I have to dive right back in again.
Oh well.
Jim
Old June 13th, 2018, 13:27   #6
Dieselmonkey02
TDI(s): 02 jetta
Yeah, it’s no shame for the miles though.
Old June 13th, 2018, 15:35   #7
JLMurphy
Originally Posted by Dieselmonkey02 View Post
Yeah, itís no shame for the miles though.
Not at all, I just kinda wish it had failed 2 weeks ago.
Old June 13th, 2018, 15:47   #8
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Did it fail? Sounds like it, but I would have it checked, pretty simple test if you got he machine. Troubleshooting battery/charging system with just a volt meter can be problematic.
Old June 14th, 2018, 02:40   #9
JLMurphy
Unfortunately a volt meter is my only tool here. Plus I figure if I have to take it out to test it I might as well go ahead and replace it. At 231,000 miles I think I can let it go.
Old June 14th, 2018, 09:24   #10
JB05
Fuel Economy: 43/41/40
I watched a video where the tech tested both DC and AC voltages. The latter was a check on the diodes; should be almost zero volts AC. He also did a voltage drop test on each of the battery cables; can't remember the maximum voltage allowed, but it should almost be 0.
JB05 is offline   Reply With Quote
Old June 14th, 2018, 10:13   #11
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Double check your pulley hasn't failed and it is allowing it to slip to the point of no charge. They either lock solid or they don't grab. I had this issue and it was only the pulley. Take the belt off, put a screw driver into the internal fan blades to hold it still and see if you can move the pulley either direction. It should allow for movement in only one direction. Neither direction is bad as is both directions.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old June 14th, 2018, 10:36   #12
ghohouston
ghohouston's Avatar
Fuel Economy: 40 Mpg
Check the connector right above the starter too. I have seen an alt wire pull out of the connector there. Replaced the alt on a buddies car for no reason. Found that afterwards.
2001 Silver Jetta Sedan TDI 5 Speed,3" Kerma turbo back straight pipe
Allard EGR Delete
Bosio DLC 764's. 1997 Ford F350 CCLB 7.3 Powerstroke Diesel ZF5, straight piped
ghohouston is offline   Reply With Quote
Old June 14th, 2018, 21:25   #13
Fahrvegnugen
Originally Posted by ghohouston View Post
Check the connector right above the starter too. I have seen an alt wire pull out of the connector.
Iíve wondered about opening that up, how annoying it pops out!
I had 160k on my alternator and a new pulley at 155k. 5k later the alternator died. I could try new brushes but an all new alt frees me up to field a failure on something I havenít messed with.
I have a Brazilian made vehicle and I still recommend taking the pass light cover off when reattaching the upper air pipe, It was the least fun of the whole job. I couldnít do it until i could see everything. My hose clamping pliers donít open wide enough for a fully open clamp.
The rebuilt Bosch alternator makes the tensioner pulley real smooth, even though the recent replacement pulley was still good.
Old June 17th, 2018, 05:21   #14
JLMurphy
Thanks for all of the ideas, I got my new alternator from idparts yesterday and put it in. Car is now charging like it should.
I did check all of the wiring and the pulley before deciding to replace the alternator, so I was pretty confident that it was the culprit.
I'm pretty sure I have replaced the pulley on this car before as it looks a lot newer than the rest of the alternator.
Bad alternator or bad pulley ? philip77o VW MKIV-A4 TDIs (VE and PD) 6 February 9th, 2015 11:21
Confirm bad alternator? conejo_a_cuatro TDI 101 10 July 17th, 2013 10:21
Alternator Workshop - Bad Alternator or VR? db52282 VW B5 Passat TDIs 9 October 24th, 2012 08:46
Alternator Pulley bad, now Alternator? danielalves VW MKIV-A4 TDIs (VE and PD) 6 July 28th, 2009 05:32
Can now confirm rubber lines+ BD = bad treedweller Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 August 12th, 2004 08:50
Page generated in 0.14691 seconds with 13 queries
[Output: 118.17 Kb. compressed to 98.96 Kb. by saving 19.20 Kb. (16.25%)]
