Old June 5th, 2018, 06:00   #1
Intech
Fuel Economy: 03' Jetta 67.1 best 51 avg. 99.5 Golf 46 Avg.
Default FOUND!! New "old" lights
What I mean by that, is that after almost thirty years, I have found the auxiliary lights, that I used to have, but unfortunately, until now, have been unable to find, ever since Wagner bought Cibie Lighting. They are the Cibie 175 for driving lights, and the Cibie’ 195 clear for fog lights. In the past decades, because I do a lot of driving, I have spent literally thousands of dollars on lighting, but never came close to the performance of Cibie’s. Only Hella came a bit closer, but nowhere near as good. I knew that someplace on this planet, there HAD to be those lights, and with the help of a friend of mine, we found them in France, brand new, still in the original boxes. I received the 175’s yesterday, and will get the 195’s next week. What makes these lights so spectacular, is their design, especially their fluting. The 175’s specs are: 6000’ reflective range, and 11 degree vertical and 16 degree horizontal fluting. The 195 fogs have a 500’ reflective range and are 10 degrees vertical and 92 degrees horizontal. With these fogs, when properly mounted and aimed, as per Cibie’, you can safely do between 45 and 55 mph in pea soup fog. I know because I used them on my wife’s Benz, and believe me when I was told this by a BMW owner, I was skeptical. But they are fantastic. The 175’s basically replace the sun after dark.
A gun is like a parachute, if you need one and don't have one, you'll probably never need one again
Intech is offline   Reply With Quote
Old June 5th, 2018, 18:22   #2
brnsgrbr
brnsgrbr's Avatar
Fuel Economy: 44 mpg
Excuse my ignorance but what will they fit? Please elaborate.
Congrats btw.
Sent from my iPad using Tapatalk
2.0Ltr ALH w/BHWs, WB girdle, IE Tuscan rods, RyanP GtB2260Vk kit, 4bar MAP; Kerma 3" exhaust w/HF cat & Aeroturbine 3030XL, headwork, DRW 6speed w/DG Sigma shifter;SBC S2 End race clutch W/ferramic disk; Peloquin TBD; Bosio Stage 2 R520s; DLI Technik mounts ; 11mm; TT CA bushings; DG Panzer FMJ, RP,& 100K TB&SB upgrade; Coolant heater; DRL & EGR deletes; ventectomy; Accuair/Airlift suspension;B20-B100
brnsgrbr is offline   Reply With Quote
Old June 6th, 2018, 04:46   #3
Intech
Congrats btw.
Fit?? Keep in mind we’re going back to the eighties. They are all quartz halogen, with leaded glass. I designed and installed a SS light bar just for them, and I also changed the Jetta front clip to one from a 2002 GTI. On that I used a set of Hella MK5 EC lights set in a MK4 housing, and am using Osram 75 watt H7 Rally lights, all direct from Germany. FWIW, the 175's have 100W bulbs and the 195's are 55W
Old June 6th, 2018, 05:52   #4
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Pictures or we don't believe it.
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old June 6th, 2018, 08:15   #5
Intech
I'll take and send pictures after the 195's arrive. I have the 175's, but I want to aim them all at once. It takes a while to set up the Cibie' aiming jig. Furthermore, I'll have to send them to you via e-mail, because I have NEVER been able to post pics on this site, and I've tried numerous times
Last edited by Intech; June 9th, 2018 at 04:38. Reason: Change: Lights are installed, and they are everything I remember. One word, Awesome
98 Jetta aftermarket "banjo" remote replacement found! Matt-98AHU VW MKIII-A3/B4 TDIs 6 May 17th, 2017 19:32
Has anyone found a fuel can to fit in the rear "cubby hole"? newbury VW MKV-A5 Golf/Jettas 10 April 14th, 2011 12:16
"ABS" and "Brake" Lights Dee Tusken TDI 101 3 December 18th, 2010 16:04
Found this interesting: "VW Approved Diesel Fuel Additive" JM Popaleetus Fuels & Lubricants 16 April 6th, 2010 02:35
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 07:06
Page generated in 0.13521 seconds with 13 queries
[Output: 76.53 Kb. compressed to 68.06 Kb. by saving 8.47 Kb. (11.06%)]
