Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old May 21st, 2018, 18:16   #1
Riker
TDI(s): 2002 Golf
Default 2002 Golf Fuel Pump
Hi, I'm new to this. I have a 2002 Golf that needs a new fuel pump, and I want to start running WVO through it. I have been told that the standard pump that's on there now can only handle about 5% WVO (B5, w/ the rest being regular diesel) Anyone know which pump I might need, or have any thoughts/comments/ suggestions? Thanks- Riker
Riker is offline   Reply With Quote
Old May 21st, 2018, 21:12   #2
MichaelB
Fuel Economy: very good
What are you talking about here? WVO? Biodiesel?
MichaelB is offline   Reply With Quote
Old May 22nd, 2018, 05:38   #3
philngrayce
Fuel Economy: 53/43/49 ('02 Jetta 5 sp)
I believe there is only one fuel pump that you can get for this car, the original manufacturer’s pump. There is an issue with some of the seals and biodiesel, which people replace with biodiesel resistant (viton?) seal. That is not an issue with WVO.
If anyone knows of an alternative pump, please tell us about it.
It is also possible that some cars (Canadian wagons, IIRC?) had an in tank lift pump? If your car is one of those rare ones, you may in fact have a seperate lift pump. In that case, you want to get something biodiesel compatible, if you plan to use biodiesel.
philngrayce is offline   Reply With Quote
Old May 22nd, 2018, 08:03   #4
atc98002
atc98002's Avatar
Riker, don't confuse Biodiesel (Bx) with WVO. Two completely different products. You can run any blend of Bio-D (B5 to B100) in your car without alteration, except perhaps replacing the seals with Viton as Phil mentioned. To run WVO, especially somewhere that gets cold like Denver, I would be much more concerned about how long it would run. Like Oilhammer mentioned in the other thread, the water in WVO can quickly cause a lot of rust damage. And you would need a really good fuel heating system to even think of using WVO in colder weather. I wouldn't even consider attempting it with a single tank system.
2018 Subaru Outback 3.6R Touring
2005 Ram 1500
2013 VW GTI: daughter
2010 Routan gone, replaced with 2018 Pacifica Hybrid: other daughter has 3 kids
atc98002 is offline   Reply With Quote
Old May 22nd, 2018, 08:23   #5
Riker
TDI(s): 2002 Golf
From what I was told by the import mechanic down the street is that processed WVO is more viscous than normal fuel if you try to run it through a normal fuel pump, it will quickly leak all over the place. I also thought that the conversion kit for a 2002 Golf included a seperate tank and a toggle switch, the idea being that one starts their vehicle on normal diesel and then switches it over to WVO after about 15 minutes.
My understanding of converting a 2002 Golf to run on WVO is that it is a 3-part process: Buy/build/learn how to use a WVO processor, intstall a conversion kit (which heats up the WVO fuel line I think), install the higher-viscosity pump.
I didn't know that WVO and biodiesel were different. I'm getting different information from almost everyone I talk to, so any clarification would be super helpful. The viton seals info was awesome (thanks Phil and atc!) My Golf needs a new fuel pump anyway, so if I can just buy the normal one, that would be helpful, but they are expensive, so if anyone has done this conversion or knows someone who has, I'm all ears! thanks!
Old May 22nd, 2018, 08:54   #6
philngrayce
Riker, I think you want to do a lot more research before making a decision. You want to be really sure you know what you are getting into.
Thre is no need to buy a special fuel pump for WVO; I don’t believe it is even possibe to buy a special one. You may also want to consider a different mechanic; thie one does not sound well versed in WVO, especially VW WVO. Are you mechanically inclined? I am hesitant to recommend WVO to anyone who is not comfortable with doing at least some of the work themselves.
As far as winter goes, WVO is no probem whatsoever. You are correct that the conversion kit heats the fuel, as well as the fuel lines and filter. I have seen far more problems in the winter with biodiesel than with WVO. As long as you switch back to diesel before shutting down, you will be fine no matter how cold it gets. I have run my cars in 30 below temperatures without a problem.
Old May 22nd, 2018, 15:16   #7
philngrayce
If you haven’t already found these sites, there is some good information here. Realize they are both somewhat biased, especially the second as it is a business selling conversion kits. Still, a lot of good information. And feel free to ask any and all questions; I enjoy discussing it and have a lot of experience, including a 2002 Jetta. You will always get a lot of good info here on the tdiclub forum.
http://biodiesel.infopop.cc/6/ubb.x?a=cfrm&s=447609751
https://www.greasecar.com
Old May 25th, 2018, 10:53   #8
SilverGhost
SilverGhost's Avatar
Highlight section - I would hesitate to recommend WVO (Waste Vegetable Oil) to anyone who makes this statement.
WVO is a feed stock that can be refined to make Bio Diesel. Much the same way crude oil is refined into Diesel and gasoline.
Heating the WVO is part of the system you install so that the stock injection pump will work.
I would recommend, from some of the statements you have made, that you start off with some BioD. Drive the car while you research the WVO to death (philngrayce is a great person to ask) before making the plunge.
Jason
Old May 25th, 2018, 11:18   #9
Nevada_TDI
Default A WVO Processor?
Are you talking about a processor to make biodiesel? There isn't a "processor" for WVO specifically as WVO generally only requires de-watering and filtering.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Old May 25th, 2018, 15:26   #10
Lightflyer1
Lightflyer1's Avatar
Stop what you are doing until you educate yourself. This isn't rocket science but you have a vast amount of knowledge to acquire before you even start doing this. It isn't something you can just jump into and be relatively successful without learning many things first. Many have failed in the past and ruined their cars. If you aren't able to work on your own car I wouldn't even attempt it. Many mechanics won't even touch one of these cars.
Old June 25th, 2018, 14:55   #11
belome
Fuel Economy: 47'ish
Also, keep in mind, if you are doing this to save money make sure you look at the cost of the kit and how many miles you plan to drive the car.
The cost of the kit and filtering system can buy a lot of diesel fuel.
If you plan to do it to help save the planet, then by all means.
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old June 29th, 2018, 10:35   #12
DudaEnergy
TDI(s): 2003 VW 1.9L
I run 100% Biodiesel and put a PD lift pump into my tank a few months ago to solve fueling issues with my performance vehicle. (I have an ALH) Does anyone have a list of what gaskets in that fuel sending assembly/pump need to be replaced? I don't want to run into problems down the road.
As to the post itself, I don't recommend WVO at all in these cars. Thick fuel is going to kill your injection pump and if you heat it, not good for the injection pump or the injectors. It'll work for a couple of years but you'll be surprised with a big repair bill at some point. Use biodiesel.
DudaEnergy is offline   Reply With Quote
1.9 TDi PD Golf MK5 lift pump / fuel tank pump MK5MK TDI 101 3 December 24th, 2017 10:31
2002 Jetta TDi - Fuel pump Recondition jenxo VW MKIV-A4 TDIs (VE and PD) 4 September 20th, 2017 08:54
2002 jetta tdi fuel pump intern1961 Private TDI Items for Sale/Wanted 1 October 17th, 2016 20:55
Fuel pump issues 2002 TDI offyourocker TDI 101 0 March 25th, 2012 12:35
WTB 10 or 11mm fuel injection pump 2002 golf pierre Private TDI Items for Sale/Wanted 4 March 7th, 2005 19:22
Page generated in 0.16581 seconds with 13 queries
[Output: 112.51 Kb. compressed to 95.78 Kb. by saving 16.73 Kb. (14.87%)]
