damac
trying to get project off the ground and am not sure if this is normal for an 02a ctn tranny.
i only drove the car about 20 miles after getting everything running and had to stop due to tranny leak even though i used new seals and bearing. will use dye and try and see why that is later.
i never noticed this nasty noise until putting car on a lift just now and taking the front wheels off. just a bit after startup to get get the tranny oil and dye circulating seems the drivers side tranny end started a howling. noticed if i push down on the end cover with my hand its less but still thats the noise.
if i push the clutch in the noise goes away.
i only got the short drive on the tranny, didn't notice performance issues. it held fifth gear on the freeway.
not sure if i should just run it and what to expect if i do, or use another tranny. thanks!
