Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > West Coast Canada/USA
West Coast Canada/USA Local discussions for those on the West Coast of Canada and the US.
Old May 9th, 2017, 10:09   #1
CATDI
Default Warning- CA residents with TDI tuning- You might fail your next SMOG check
Hi:
A friendly warning to California residents with a TDI and aftermarket tuning.
You might not pass your next SMOG check even though you passed several times before.
How do I know?
It just happened to me. My 2005 BHW Passat TDI with Rocketchip RC1 failed the most recent smog check. I was shocked. I had no check engine lights and the car had been running just fine.
I never had an issue before with the last 3 SMOG checks.
More details on my issue including a graph of the MAF here
I tried to find a problem but couldn't. I did verify that EGR readiness was failed or incomplete via VCDS. Could never get it to set because the MAF-S was constant. When that happens, there is no way EGR readiness will ever set.
Why did my car pass before?
Effective May 4, 2015, all available readiness monitors must be set. Previously you could have any one not set. This is why my tuned TDI could pass before without issue.
Full details from CA BAR here
So make sure your tune is up to date and all readiness monitors are in the pass state before your next smog check!
Now if I could only get a hold of Jeff at Rocketchip.
-Ed
CATDI San Jose, CA
2006 Jetta TDI Pkg 2 w/ RC1+
2007 2500 Duramax LTZ
2015 Golf SW TDI SEL (Father)
Truly a diesel family...
CATDI is offline   Reply With Quote
Old May 9th, 2017, 12:54   #2
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
He's really not all that hard to get ahold of.. mid morning is usually a good time to call. remember he's in the eastern time zone
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old May 10th, 2017, 06:15   #3
devonutopia
devonutopia's Avatar
Forgive the dumb question, but what is the smog check? Over here in Blighty, we have an annual MOT test where the exhaust on a TDI is subject to a particulate test. Wondering if its the same thing? Or similar at least.
Jason - Skoda Fabia TDI project
http://www.youtube.com/watch?v=TOE4nbT5NGY 315bhp dyno run video of my car.
http://www.youtube.com/watch?v=8R5c496IG1Q Skoda Fabia GTB2260vk in-car acceleration video!
http://www.devoncardetailing.gb.net/
devonutopia is offline   Reply With Quote
Old May 10th, 2017, 06:37   #4
Layerz
Hopefully I don't get this too wrong!
But I understand in many states they have the yearly tests which isn't quite as much as an MOT but also CA is super strict has has road side smog tests.
Flip side I think you can get away with Murder in Florida and convert a FWD car to AWD/RWD with very little fuss/if at all any care.
Layerz is offline   Reply With Quote
Old May 10th, 2017, 07:09   #5
john.jackson9213
TDI(s): 1996 B4V
It is an emissions compliance test. Similar to your particulate test. The very first part of the test is a readiness check with the engine computer and the "check engine" light on the dash. Fail at that point - ends the test immediately. This is in California, other states are different. But many follow the California example on vehicle emissions.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old May 10th, 2017, 07:35   #6
Ed ke6bnl
Ed ke6bnl's Avatar
time to find that special smog tester.
1950 F1 street rod,1949 F1 stock V8 flathead
1948 F6 350 chevy/rest stock, no dump bed
1953 chevy 3100 AD, 4BT cummins motor, NV4500
1968 Baha Bug with 2.2 ecotec motor
1998.5 Dodge 2500 4x4 Cummins,2002 Vw Jetta
Ed ke6bnl is offline   Reply With Quote
Old May 10th, 2017, 08:24   #7
Layerz
Am I right too that you can be roadside tested if pulled over too?
My understanding in CA is that mods are targeted by the police too, would be handy to correct my understanding if wrong here.
Old May 10th, 2017, 09:02   #8
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
As mentioned, each state has different requirements. In North Carolina, all cars are subject to an annual safety check (horn, lights, signals...) and gassers have to have an emissions test. If you have a gasser with a check engine light on, it's an automatic failure. On the diesels, the check engine light is ignored. My beetle had a check engine light on for at least the last five years I owned it and it passed every time. The check engine light was due to a fault to the airbag.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
kjclow is offline   Reply With Quote
Old May 10th, 2017, 10:02   #9
flee
flee's Avatar
Fuel Economy: 40-ish
In reality, roadside testing is a rare phenomenon.
I have seen it maybe once in the last 45 years driving in southern CA.
There is a phone number one can call to report 'gross' polluters, though.
2002 Jetta GLS TDI wagon
flee is online now   Reply With Quote
Old May 10th, 2017, 19:43   #10
john.jackson9213
TDI(s): 1996 B4V
Roadside tests are for gathering real world data. No danger to registration from participating in the roadside test. I was in one earlier this year for the first time. Got my California drivers license in 1965.
If you have a muffler loud enough to tee off your neighbors and they complain. Yes, you might get a ticket. If your car belches blue clouds of smoke where ever you drive, yes you might get a ticket. As flee said, you can call a phone number and report excessive smoke.
Do the cops target modified cars? Seriously NO. I find it amazing how these tales get spread. It usually involves a stupid driver doing something stupid, unsafe to attract attention. They get stopped, then want to argue with the cop. Funny how that works. About 5 years ago, I saw a jerk on a motorcycle go on the wrong side of the road to pass a couple of cars. Unfortunately for him, there was a San Diego motorcycle cop coming around the corner. Loved seeing that guy get pulled over!
JJ
Old May 11th, 2017, 01:31   #11
Layerz
Thanks for the clarification - and tbh thinking about the context of where I've heard this from (various sources/people) on cops pulling more cars in CA actually I should of correlated people with aggressive/extreme mods with similar driving and likelihood of getting pulled.
Old May 11th, 2017, 09:14   #12
2many diesels
"Effective May 4, 2015, all available readiness monitors must be set. Previously you could have any one not set."
Don't think this is completely true.
I have run 4 cars through emmisions testing in the last month. One in particular, 2001 audi A4 1.8t...This car is not required to pass the evap test...and it didnt. I knew that when I set the car up for testing so I wasnt concerned. Didn't pass evap, but did pass test.
2many diesels is offline   Reply With Quote
Old May 11th, 2017, 12:14   #13
romad
romad's Avatar
I passed w/o a problem in September 2016 and my Malone Stage 1 tune with Dynamic EGR & Dynamic Idle.
The fleet:
romad is offline   Reply With Quote
Old May 11th, 2017, 20:05   #14
pappyhat
TDI(s): 2004 Wagon
Just received my 2017 DMV renewal for my 2004 Jetta Wagon. It states I must go to local dealership for my Mfg Recall #28F6. I wonder what this is?????? Then with my Proof of Correction Certificate and Smog certificate send to DMV... I have RC 1+ and have passed previous years smog tests...
pappyhat is offline   Reply With Quote
Old May 11th, 2017, 21:47   #15
romad
romad's Avatar
That is a recall from 2011 on the glow plugs. Just take your VIN into a dealer and ask for a list of completed recalls on that VIN.
The fleet:
2005 Golf fail CA smog test jaysonl76 TDI (Diesel) Emissions 0 August 24th, 2016 09:41
CA Smog FAIL after 5spd swap/tune wulferus VW B5 Passat TDIs 17 July 30th, 2016 22:34
check engine light and CA smog new/used golf 2006 TDI 101 4 May 27th, 2016 16:03
HELP! Check engine light is not visible...failing CA smog check. redscare TDI 101 3 April 4th, 2011 22:20
CA smog check ?..........EGR readiness invader TDI (Diesel) Emissions 6 April 3rd, 2011 12:22
Page generated in 0.17060 seconds with 11 queries
[Output: 132.54 Kb. compressed to 111.14 Kb. by saving 21.40 Kb. (16.15%)]
