Old March 25th, 2012, 12:35   #1
offyourocker
TDI(s): 2003 Jetta
Default Fuel pump issues 2002 TDI
My 02 Jetta TDI would not start. Went through the troubleshooting steps I found on here and realized I was not getting diesel to the injectors and that the fuel pump was leaking. I replaced the seals as shown on the recommended 7 youtube videos. Put it all back together and it is still leaking. I think it is leaking at the solenoid valve for start of injection. At least the diesel seems to be running along that wire. Is that possible. Can I remove the fuel pump totally to have it rebuilt. If so, is there timing issues when putting it back on.
offyourocker is offline   Reply With Quote
2002 Jetta TDi Injection Pump and other issues jenxo VW MKIV-A4 TDIs (VE and PD) 12 March 26th, 2012 23:46
Leaky fuel injector pump in 2002 Jetta TDI teeps VW MKIV-A4 TDIs (VE and PD) 5 August 24th, 2011 15:36
2002 tdi strange fuel issues trying to get it started rxweelo VW MKIII-A3/B4 TDIs 1 June 7th, 2009 21:09
2002 Beetle Fuel Injection Pump issues kehughes90265 TDI 101 7 October 1st, 2008 19:35
2005 Jetta fuel filter & fuel pump issues - seeking advice mvoss15 VW MKIV-A4 TDIs (VE and PD) 6 September 22nd, 2008 07:49
Page generated in 0.12844 seconds with 11 queries
[Output: 46.68 Kb. compressed to 44.00 Kb. by saving 2.68 Kb. (5.74%)]
