Old October 17th, 2011, 19:26   #1
physicshogon
TDI(s): 2012 Passat
Fuel Economy: [URL=http://www.fuelly.com/driver/Olivia/passat][IMG]http://mefi.us/images/fuelly/sig-us/92859.png[/IMG][/URL]
Default VCDS tricks?
I see a lot of guys here talking about coding using VCDS. What exactly is it, where can I get one, and what cools "tricks" can I do to my car's electronics with it?
physicshogon is offline   Reply With Quote
Old October 17th, 2011, 20:28   #2
jef@rosstech
Associate Ross-Tech Vendor
What is VCDS? In a nutshell, a way to turn your Windows based laptop into a dealer level scan tool.
http://www.ross-tech.com/index.html
What "tricks" can you do? Well, it really depends on the control modules in your car. For example, if you have a 2008 Jetta, you can turn off your DRLs and make the windows roll up and down with the remotes. However, if you have a 2002 Jetta, you can't do those kinds of things with VCDS since the 2002 Jetta's control modules doesn't support that.
If you work on your own car, then you have wrenches, sockets, screw drivers and so on. Since 1990, working on VWs also means being able to talk to the control modules in the car, and that is what VCDS allows you to do.
If you have any questions, post them up here or feel free to call up our sales department (phone number on our website).
Thank you.
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old October 17th, 2011, 22:41   #3
rallyruss
rallyruss's Avatar
how about enabling or disabling the "throttle" on a B 5.5 passat TDI?
98 TDI jetta BillyHDs, Softsports, 16"wheels, corrado brakes, running B99. PP520s and chip to match and some other stuff....250k+
(Hers) 05 Passat TDI GLS wagon. Unchained, Koni FSDs, RC2, audi S4 wheels and full tint.
rallyruss is offline   Reply With Quote
Old October 19th, 2011, 12:50   #4
Uwe
Uwe's Avatar
The "Throttle" on that motor is an integral part of the engine control system and cannot be "disabled" with a scan tool.
-Uwe-
__________________________________________________ ___
VCDS®:
Satisfaction guaranteed or double your fault codes back!
Uwe is offline   Reply With Quote
Old October 19th, 2011, 13:27   #5
jef@rosstech
Can you elaborate on what you are asking. I am guessing you are asking about the "motor for intake flap, V157" but not sure since diesel engines do not have a throttle body like gasoline engines.
Jef blah blah blah
www.Ross-Tech.com
Old October 19th, 2011, 15:48   #6
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
-Uwe-
You guys need to develop the same software for Ford ...... especially the F150.
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old October 20th, 2011, 18:00   #7
Uwe
Uwe's Avatar
Thanks, but VW/Audi keeps us pretty busy.
-Uwe-
VCDS®:
Old October 20th, 2011, 22:49   #8
rallyruss
rallyruss's Avatar
during the process of installing the Rocket Chip 2 tune on our passat. The function of the "motor for intake flap, V157" was disabled along with the EGR function. If I remember correctly this was done separate from the "chip" reprogramming using VCDS.
I have attempted to contact Jeff from Rocket Chip to clarify without success.
I would like to temporarily re enable this function for to get the monitors to clear.
If it is not possible thru VCDS I will have to find other methods to get around this issue.
Old October 20th, 2011, 22:56   #9
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
No it is not possible with VCDS. It can be done ONLY with tuning ECU.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
CV Tricks soup nazi VW MKIII-A3/B4 TDIs 8 May 23rd, 2011 06:56
Cat Tricks HOOPER65 Ontario 43 April 3rd, 2009 12:58
vag-com tricks Mr.Pain TDI Power Enhancements 6 March 3rd, 2007 06:33
any tricks? OhMagoo Ontario 6 September 21st, 2006 18:16
VAG-Com Tricks? POWERSTROKE TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 14 November 4th, 2003 21:33
Page generated in 0.14263 seconds with 11 queries
[Output: 94.96 Kb. compressed to 81.33 Kb. by saving 13.63 Kb. (14.35%)]
