Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old January 3rd, 2019, 09:16   #1
roggen1of8
Default car pulls to left when i accelerate
I have a 2003 jetta wagon tdi. 364000+ miles. All front end parts are either new or in good condition. I just replaced the front struts and springs. Monroe quickstrut 171525. The top flange mount for the strut will not set tight to the body. According to my front end guy he says they don't. That it is a VW design. True or not?
Also, when I accelerate the car pulls to the left and when I take my foot off of the accelerator it then pulls to the right. Most noticeable at speeds over 40.
What ya all think?
roggen1of8 is offline   Reply With Quote
Old January 3rd, 2019, 10:49   #2
oilhammer's Avatar
Fuel Economy: fantastic
Those quickstruts are junk. They are double plus junk on that application.
Just get some quality struts, springs if necessary, and upper mounts and put it back the way it is supposed to be.
I seriously take SO many of those stupid things out and chuck them in the scrapper. What sucks is, then I have to order the upper spring perch since the OEM stuff is all generally missing.
www.cardocautomotive.com
Old January 7th, 2019, 08:54   #3
roggen1of8
Ok thanks for not answering my question. yes you don't like quick struts and even in your professional opinion that is a personal choice. So, leaving that aside can you give me any ideas why the car is pulling to the left when I accelerate?
Old January 7th, 2019, 10:39   #4
oilhammer's Avatar
The upper mounts of the quickstruts are unable to keep the strut assembly in proper geometry, because they are of low quality.
Like I already said.
You said the rest of the front end parts are good.... I took that to mean the control arm compliance bushings are also good... and if they are, the only other thing that causes torque steer to that degree is the UPPER mounts.
It is a simple Mac strut front suspension, same as any other, although some cars have an actual fastener to attach the upper mount to the body, some just let it sit in a pocket (like on this application). The upper disk and nut keep the strut assembly from dropping out of the pocket when the car is lifted off the ground. This is not unique to Volkswagen, but not common either. Fiat 500s are like this too.
I am sorry if you do not like my answer. But you asked.
Old January 7th, 2019, 10:47   #5
Vince Waldon
Vince Waldon's Avatar
Yes, this is true. Been that way since the early Rabbits.
Your car is throttle-steering because something in the car's front suspension or steering geometry is changing under engine torque.
If this just started after you changed struts the struts are of course the prime suspect. Otherwise, any wear item in the car's front suspension or steering is a possibility... aside from the struts themselves there's:
- ball joints
- outer or inner tie rods
- upper strut bearings / bushings (did they get replaced when you did the struts?)
- any of the control arm bushings
Potentially loose subframe bolts could cause this as well, but likely you would have heard noise already.
Did this start *after* you changed struts?
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old January 23rd, 2019, 18:35   #6
Fahrvegnugen
I replaced everything but the struts themselves, and I have the same situation. I checked it over and tightened everything, and still get the pull to the left. I had a couple of shops check into it and they didnít find anything wrong, so when I get on it I have the turbo spooling noise sooth me while holding the wheel straight. It rides nice until I goose it.
Fahrvegnugen is offline   Reply With Quote
Old January 24th, 2019, 20:19   #7
My_name_is_Rob
My_name_is_Rob's Avatar
TDI(s): 97 Vento
Fuel Economy: 46 mpg
My mk3 does this, but it pulls to the right when accelerating. I even went as far as to change the engine mounts, and it still does it. Next on the list is an inner and outer tie rod for the right side, and sway bar bushings.
My_name_is_Rob is offline   Reply With Quote
Car pulls left when accelerating, why? NewtsTDI VW MKIV-A4 TDIs (VE and PD) 7 March 1st, 2015 15:47
Car pulls to left when accelerating... Poroto VW MKV-A5 Golf/Jettas 1 January 31st, 2011 22:34
car pulls left on acceleration suffeks VW MKIV-A4 TDIs (VE and PD) 10 November 2nd, 2003 20:37
car pulled left, now it pulls right labenge VW MKIV-A4 TDIs (VE and PD) 6 August 17th, 2002 00:17
New car pulls to left Imran Upgrades (non TDI Engine related) 1 November 15th, 2000 06:04
Page generated in 0.14103 seconds with 13 queries
[Output: 83.13 Kb. compressed to 72.13 Kb. by saving 11.00 Kb. (13.24%)]
