apari006
I seem to have the same problem with my 2001 Jetta, line (#10/O-ring#11) going into the block. Good thing is the timing belt will be replace soon.
Is it as complicated to replace as JETaah says when you replace the water pump?
A
Woulld anyone have the PN for this (line and O-ring)?jasonTDI said:Are you shure it's not the hard plastic tube that comes strait out of the block under the inj pump? That's about $14 at the dealer with the oring.
A
